The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (47 BOMBER, MPandC), 240 guests, and 3 robots.
Forums47
Topics117,681
Posts941,455
Members43,024
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: 1952 3100 Dual Master Cylinder Conversion
ssaxman #1325856 Thu Sep 12 2019 01:58 AM
I've kept original drum/drum front and rear. Zero issues due to locating dual master under floorboard. Seems to be about same level as the wheel cylinders, maybe.
1. Shot from underneath shows old floorboard hole in front of new master. Tee also visible at bottom of pic.
2. Line from master back port goes into left side of tee. Lines from right side of tee and bottom of tee goes to the two front brakes. Line from master front port goes to rear brakes.
3. Shows the extra floor hole cut for new master. Master lid can lift out through the 3" hole pretty easily.(use a big syringe or turkey baster for easy fill) My oldest ugly floormat goes against floorboard. On top of that is sound/heat mat. Those two were cut to fold over and weighted down for easy access. Nice floormat on top.
4. Last pic shows my bench bleeding setup. Be advised the reservoirs are much smaller than modern disc masters, so FILL OFTEN as you bleed wheel cylinders. I ran them dry on first bleed because they're so small! Had to remove the master and bench bleed all over again. dang
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com
Skooter #1325864 Thu Sep 12 2019 02:33 AM
ssaxman Offline OP
This is awesome, Skooter! Thanks so much for posting the pics and descriptions. This will help a LOT! I'm hoping to find the time to get this completed sometime this month or next and will definitely post some pics of my install. Thanks to everyone who's replied; the help is much appreciated!
ssaxman #1325881 Thu Sep 12 2019 07:01 AM
Looking at scooter's install photos, I'm wondering what would prevent moving the master farther forward to use the original fill hole in the floor. Maybe it's because the dual master mount flange is wider than the old master where the original bracket is.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
ssaxman #1325882 Thu Sep 12 2019 09:25 AM
ASU Offline
maybe I am missing something...On Skooter's set up, If there is 1 line coming from the master, which tee's and goes to the front and back brakes, Isn't this the same as the original system, only with a different MC? 1 leak anywhere in the system would render all the breaks useless. The purpose of a dual reservoir system is to separate the front brakes from the back brakes, create 1 reservoir and piping system for the front, and 1 for the back, so you don't lose everything at once.
Jon
ASU #1325889 Thu Sep 12 2019 12:37 PM
Jon
His step 2 sounds like he has separated the front and rear:
ssaxman #1325915 Thu Sep 12 2019 05:41 PM
ssaxman Offline OP
Will residual pressure valves be needed when converting to the dual reservoir setup?
ssaxman #1325925 Thu Sep 12 2019 07:28 PM
Depends on the master..........some have the residual valves built in.
ssaxman #1325929 Thu Sep 12 2019 08:48 PM
That is where the "fun" comes in to play. The stock configuration with the original single master cylinder incorporates different sizes of brake lines (on some models) in order to supply front and rear wheel cylinders with the appropriate balance.
With adding a dual master which is not designed to work on our trucks, you now have to rely on seat of the pants information to determine if you need to add a proportioning valve to make it work.
Then while trying to determine if you have a front-to-back brake balance problem, you won't know for sure whether the imbalance is actually caused the dual master, or due to new brake shoes which are not yet arced to mach the contour of the drums yet, or improper brake shoe adjustment.
A set of challenges, but doable over time. Just don't do any tailgating in the meantime.
Carl
52Carl #1325933 Thu Sep 12 2019 09:19 PM
Sorry, but line sizes have absolutely no relationship to balance between front and rear. It's strictly controlled by the ratio of master cylinder and wheel cylinder diameters.Differences in line flexibility would be the only thing that would impact balance and there's no real flexibility in the lines. Unless one of the lines is essentially microscopic (and they're not) it would not be able to restrict flow of the fluid going to the wheel cylinders.
A dual master cylinder without a proportioning valve and the same size bore on both circuits would work just like the original single reservoir master.
showkey #1325953 Thu Sep 12 2019 11:34 PM
Originally Posted by showkey
[quote=ASU]maybe I am missing something...On Skooter's set up, If there is 1 line coming from the master, which tee's and goes to the front and back brakes, Isn't this the same as the original system, only with a different MC? 1 leak anywhere in the system would render all the breaks useless. The purpose of a dual reservoir system is to separate the front brakes from the back brakes, create 1 reservoir and piping system for the front, and 1 for the back, so you don't lose everything at once.
Jon
Showkey is correct thumbs_up
"On Skooter's set up, If there is 1 line coming from the master, which tee's and goes to the front and back brakes..."
No. One master port goes to the tee, then tees to both front brakes (left and right). The other master port goes to the rears.
Page 2 of 3 1 2 3
Moderated by  SWEET
