The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (62Stick, klhansen, agedhorse), 47 guests, and 4 robots.
Forums47
Topics117,751
Posts942,134
Members43,036
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Thoughts on AD trucks
#1325498 Mon Sep 09 2019 08:34 PM
49 3100 Offline OP
I have a 49 and a 51 both 1/2 ton. Have learned quite a bit, as I am not a mechanic. If you need to replace your bed--MarK is your best bet. If you want to spice up your bed rolls try this. I bought 1 1/2 Freeze plugs, changed the washer to SS, with a new SS acorn nut--look Great and you can do the front also--which keeps out the Wasps. If you need new rubber for the cowl--, or elsewhere, Buy from Steele--they are pricey, but the best. Added 848 heads and Fentons to both for a little more HP. Both trucks came with 1954 235 Engines. Radial tires are a must for a smooth ride. If you need heads have them checked B4 you get them for cracks, shipping is pricey.. Had to have a crack repaired, thankfully it only had one..Bill
P.S. forgot to mention--if you go with Fentons-Buy Remflex gaskets from Amazon-they had the best price...................
Re: Thoughts on AD trucks
49 3100 #1325503 Mon Sep 09 2019 08:50 PM
Good comments.
49 3100 #1325534 Mon Sep 09 2019 11:55 PM
Bill - thanks for the info - will definitely be looking at Mar-K and Steele for my 51 3100.
Charlie
'51 3100 5-Window (Restomod in progress)
49 3100 #1325744 Wed Sep 11 2019 12:55 PM
Thanks for the comments Bill.
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
49 3100 #1325790 Wed Sep 11 2019 06:55 PM
You can also put bed lights in the rails. the rails are 2 different sizes.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
49 3100 #1325817 Wed Sep 11 2019 10:54 PM
My thoughts after having my '53 model for 19 years:
1. Having a nicely restored truck is wonderful...except you can't really use it for what it was intended for. Enjoy a nice patina truck that you can fill the bed up with dirt or firewood, and not fret over every little scratch and door ding.
2. While I like original factory spec trucks, a few modern touches would certainly be nice. Disc brakes, electric wipers, electronic ignition. I am even opening up to the ideas of air conditioning and modern driveline upgrades.
3. Remflex manifold gasket does seem like a smart choice
4. Things go bad when vehicles sit in storage. Regular driving seems to make my truck behave. These trucks were meant to run and use, not show, shine, and perfectly preserve.
5. I carry a small can of starting fluid in the drivers side cab corner. Sure helps when it's super hot outside, when you shut the truck off and the fuel vaporizes in the carburetor. A 1-second squirt down the carb, hit the starter, and you're back in business.
6. 261 & 4-speed > 216 & 3-speed
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Green_98 #1325959 Thu Sep 12 2019 11:57 PM
Absolutely!! I don't think that can be overstated. In the 37 years I've owned mine frequent use has been the key to happiness. Periods when she's sat for a few months...she was never easy to deal with. Ya get busy with life and one or two months becomes six or a year before you know it. big_eek
Aside from that, the best thing I ever did for my truck was install a new fuel tank after struggling for years with sporadic rust/sediment issues with the old tank. Those problems vanished and now a clean glass bowl strainer always! grin
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com
Moderated by  Justhorsenround
