The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (LAROKE, ASU, 1 invisible), 248 guests, and 3 robots.
Forums50
Topics120,034
Posts961,343
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1954 Panel Truck
#1325811 Wed Sep 11 2019 09:52 PM
Hello Everyone,
So I purchased this 1954 Panel Truck about a year ago. It’s not been on my project list until just this past week. So I removed the front clip in order to replace the engine. That all went well... removed the engine with no troubles. During the clean up I discovered a major crack in the frame right by the leaf spring bracket. I’ll add a picture.
So my question is how hard is it and how do I remove the body?
Thank you.
Scott
[img]https://www.stovebolt.com/ubbthread...BD4EE78-134D-4562-9950-AA0D63ADFF00.jpeg[/img]
Chevytruckdaddy
Re: 1954 Panel Truck
chevytruckdaddy #1325824 Wed Sep 11 2019 11:41 PM
looks like a failed repair.
chevytruckdaddy #1325830 Thu Sep 12 2019 12:36 AM
General Purpose
Very bad repair. Looks like spring hanger is even welded. One idea is to replace frame. The fix is a good size job.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
chevytruckdaddy #1325836 Thu Sep 12 2019 01:21 AM
Thank you for your reply, I have a replacement 54 frame so I’m just going to do a swap. What do I need to do to remove the body from the broken frame? I know I’ll need to remove the steering column and the gas tank filler neck. I have a fork lift so picking up the body will be easy.
How many mounting bolts are there? Anything else I need to be looking at?
Thank you
Scott
Chevytruckdaddy
chevytruckdaddy #1325839 Thu Sep 12 2019 01:33 AM
General Purpose
Probably about 10 bolts. You will just have to examine. You also have your pedals, wiring, gas lines to tank, transmission shifter, speedo cable, battery cables, body to frame ground strap....
The ideal method is to lift body, roll out chassis, roll in a wooden wheeled body dolly and set body down. Roll chassis to work area. Move body aside on dolly.
chevytruckdaddy #1325842 Thu Sep 12 2019 01:36 AM
All those carriage bolt heads you see on your floor? Those are your body mount bolts. It's been a while but, two in the footwell, two behind the seat, two mid-floor and two at the rear. I might be missing a pair.
chevytruckdaddy #1325843 Thu Sep 12 2019 01:39 AM
Yup, I missed a pair. Two in front of the rear wheel well, two behind the rear wheel well and two on the rear deck. Plus the already mentioned front floor and behind the seat.
chevytruckdaddy #1325845 Thu Sep 12 2019 01:42 AM
Awesome, yes I’ve removed all then wiring and pedal. 10 bolts sounds as easy as removing the front clip. That only tool me 45 minutes to remove.
[img][/img]
Chevytruckdaddy
chevytruckdaddy #1325847 Thu Sep 12 2019 01:44 AM
General Purpose
I've been adding to the removal list. I think you have it all covered. Good luck.
chevytruckdaddy #1325848 Thu Sep 12 2019 01:46 AM
I wouldn't attempt to repair a frame that far gone. I'll bet you find other stuff that's "not optimal" as well. Good that you have a spare frame to swap out.
Bartamos, that "wing" thing behind that POS repair is the front body mount bracket.
Scott, sorry I don't know how many mounting bolts on a panel, but one of the guys can probably answer that question. You'll need to pull the steering wheel, unbolt the steering column from the frame, and remove the brake and clutch pedals (they bolt to their lower arms in front of the firewall. Also, misc engine controls (throttle pedal linkage, parking brake linkage, etc.) will need to be removed. You could lift the body off without removing the steering column, but you'd have to move the frame forward as you lift to clear it.
on edit: I see the engine is already removed, which will make things easier.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
chevytruckdaddy #1325849 Thu Sep 12 2019 01:47 AM
Ok nice I’ll cut those bolts tomorrow and make a rolling cart to support the body. I’ll add photos tomorrow evening.
Thank you
Scott
Chevytruckdaddy
klhansen #1325851 Thu Sep 12 2019 01:51 AM
No I agree with you, removing the steering column is an easy task pulse I’ll need it for the new frame swap.
Chevytruckdaddy
chevytruckdaddy #1325916 Thu Sep 12 2019 05:55 PM
Easy dolly.
chevytruckdaddy #1325918 Thu Sep 12 2019 06:06 PM
ace skiver
Very nice, Mark
Something to consider: if you stacked two more rows of 6x6s, you might be able to paint the whole body on that assembly?
The extra height would get it up enough to reach the entire curved bottom-edges?
That is what we did with my ‘54 Suburban.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
chevytruckdaddy #1325965 Fri Sep 13 2019 12:29 AM
That was back in 2006. Paint wasn't a consideration back then. Just frame work. It would make life easier if I still had it on the dolly!!
chevytruckdaddy #1325997 Fri Sep 13 2019 08:45 AM
I removed my panel body. There were 10 bolts. I used travel trailer tipout screw jacks on all four corners to raise it.
You said you had a replacement '54 frame; Is it a panel or Suburban frame? Pickup frames are missing the panel truck body mounts. They can be fabricated fairly easily however, or you can transfer them over from your cracked frame.
1951 Chevy Panel Truck
chevytruckdaddy #1326075 Fri Sep 13 2019 10:24 PM
General Purpose
Hey Mark, you don't sound like Darth anymore
chevytruckdaddy #1326148 Sat Sep 14 2019 03:52 PM
grin grin chug
chevytruckdaddy #1326181 Sun Sep 15 2019 12:07 AM
General Purpose
I thought you would want to change the Avatar text to match your new pic?
chevytruckdaddy #1326386 Mon Sep 16 2019 05:47 PM
I'll leave it just so everyone will be left feeling how I feel every morning when I wake up. Dazed and confused.
Page 1 of 2 1 2
Moderated by  tclederman
