The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (3B, Eisenhart1992, 68ironhead, carbking, Doc.Hall, 3 invisible), 145 guests, and 3 robots.
Forums50
Topics119,009
Posts952,668
Members43,313
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Help me understand the 4.10 upgrade
#1325522 Mon Sep 09 2019 10:27 PM
I’m slow. I admit it. Have been reading about the conversion to a 4.10 rear end. Some have said it’s a direct replacement and fairly straightforward process. What is missing in my understanding, are the comments about the pinion gear.
I’m assuming that with this swap both the ring assembly and pinion gear are required? Is this correct? I acquired a 67-72 4.10 pumpkin years ago...that has been aitting on a shelf but the pinion is missing.
Re: Help me understand the 4.10 upgrade
tom moore #1325525 Mon Sep 09 2019 10:57 PM
3B Online
Hy tom moore, the pinion and ring gear are a matched set, if you have a differential center section with no pinion gear then the minimum you would have to do to install it would be to purchase a ring and pinion gear and have them installed and set up in your center section, hope that helps.
tom moore #1325540 Tue Sep 10 2019 12:08 AM
That was my understanding too.
tom moore #1325549 Tue Sep 10 2019 12:47 AM
If you’re missing the pinion you’re starting from scratch on the hunt for another 4.10 pumpkin.
You only need the gears I suppose, but you’re much more likely to find the whole assembly than to find just the matched set of gears.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
tom moore #1325606 Tue Sep 10 2019 12:01 PM
Easiest way to do it is with the whole assembly. When I did the conversion on my 1-ton a loooong time ago I believe it was as easy as disconnect the driveshaft (can't remember what I did there) pull the axles out of the differential and then remove and replace the 5.14 pumpkin with the 4.10 unit. I didn't have a good shop setup at the time and did it with the truck on the ground. I'm sure there were some other minor steps that I had to do but can't recall off the top of my head. Made a world of difference after the switch. 55 mph didn't sound like I was going to blow the motor!
tom moore #1325607 Tue Sep 10 2019 12:29 PM
Have you read this tech tip?
https://www.stovebolt.com/techtips/axles/1%20Ton%20Upgrade/
Part 1 step 3, the ring gear will have (among other numbers) 10:41 stamped on it. The number of gear teeth on pinion and ring gear; with some simple math this is the gear ratio.
I don't recall what the pinion has on it for numbers but it may have a serial number matching one on the ring gear or something indicating the matched set.
tom moore #1325645 Tue Sep 10 2019 04:52 PM
thanks, I'll read that tip. I have more experience with these AD and pre-war torque tube assemblies than i do with an open driveline. After reading this, i made a mistake thinking the pinion gear was attached to a propellor/drive shaft ... like the torque tubes. In my haste I forgot that the pinion for this 68 differential was enclosed in the case with the ring, bearings and seals. To make a long story short, I’m all set and have a complete assembly.
I cant believe I made that mistake.
Moderated by  Grigg
