The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (DIY.MechanicMike, Jimmie D, jmoore, Apache1, 3 invisible), 424 guests, and 3 spiders.
Forums48
Topics117,297
Posts937,860
Members42,893
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: NV4500 swap [Re: Twinstick] #1325464 Mon Sep 09 2019 05:01 PM
TUTS 59 Offline
I just finished a rebuild on the NV4500 in my 93' K1500. The rebuild was just to freshen up the bearings , syncros and seals. It went pretty smooth even with having the transfer case involved. I was following this thread and believe that the bellhousing is much the same as the older style 60's GM's. as the clutch fork is on the right hand side. You may need to redrill and tap the mounting holes but that should do it. Speedway has a hydraulic release bearing that will work with the original bellhousing and will eliminate the clutch fork, it's not that costly around a $100.00. wink
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Re: NV4500 swap [Re: whateverpratt] #1326396 Mon Sep 16 2019 06:25 PM
wahl4m Offline
if im thinking right ?? leon used the non hyd clutch ?? i need to find the site & reread it ! like i said i will be going to leons house soon -this fall & can ck it out ? im doing a 66 c-30 car hauler & would like to use the same trans -set-up ! thanks mike
Re: NV4500 swap [Re: Twinstick] #1342431 Thu Jan 16 2020 03:14 PM
Foghorn Leghorn Offline
Does anyone know which speedo gear I need in a nv4500 for a 235 Chevy? I have 4.57 gears in rear end.
Re: NV4500 swap [Re: Twinstick] #1342433 Thu Jan 16 2020 03:41 PM
Is the output standard duty or heavy duty for the dodge nv4500? I would assume standard duty but just wanted to check. Thanks
Page 2 of 2 1 2
Moderated by  Hambone
Powered by UBB.threads™ PHP Forum Software 7.7.3
