The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (55 SHAKER, Coltonk, hotshoe99, Doc.Hall, 49nut, 1 invisible), 142 guests, and 3 robots.
Forums50
Topics119,012
Posts952,696
Members43,313
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Free Air - Anymore?
#1325169 Fri Sep 06 2019 11:41 PM
Most of the gas stations here have become mini-marts and air if available is not free. Some vendors will turn on the pumps if you buy something but the last time I used one I had to have him reset the pump 4 times. Very weak pressure and it was obvious it had not been used much as there was a lot of water vapour in the air.
I have a bicycle pump that goes up to 120 psi and wonder if it would work. Its they style that you stand on flaps on the base and use both hands to pump. Anybody tried it?
Also may have to buy one of those 12 volt battery powered units that plug into the cigar lighter. The lighter in my truck does not work.
I only need it to top up the pressure.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
Re: Free Air - Anymore?
Sedgewick #1325171 Fri Sep 06 2019 11:58 PM
Boltergeist
Find a vehicle in a salvage yard that has air shocks or air suspension and scavenge the battery powered air pump from it. The Buick Rainier (Fancy Chevy Tahoe) that I drove for a while even had a built-in air hose in the right rear by the tailgate that could reach all the tires.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Sedgewick #1325335 Sun Sep 08 2019 05:48 PM
Good idea, thanks.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
Sedgewick #1325339 Sun Sep 08 2019 06:46 PM
I believe some states have a requirement for gas stations to provide air for free, CT and CA come to mind.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Sedgewick #1325382 Mon Sep 09 2019 12:42 AM
I think Indiana requires it to be free if you ask.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Sedgewick #1325444 Mon Sep 09 2019 03:29 PM
I have one at the house I bought in the 70's that I haven't seen any others like it. It's a 110v unit but we had a generator we carried with the circle track car. You set the pressure, use a clamp on chuck and when the pressure is met it freewheels. If left sit and the pressure drops below setting it kicks back on. No reserve tank, just the compressor.
Evan
Sedgewick #1325512 Mon Sep 09 2019 09:13 PM
There are States that make air free. Here in the great wet north I don't know. Every place I tried they wanted a buck and the air supply was so weak it would hardly fill a tire.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
Moderated by  Bouncer, Justhorsenround, Tiny
