I am trying to remove the transmission from my 1935 Chevy Fire Truck ( 1.5 ton ) and I am unsure about removing the trunion bearing at the tail of the transmission. My service manual says to remove the locks holding them in and drive out the bearing. I have found the lock wires inside the trunion bearings and removed them...I have been driving out the trunion bearings but is there enough clearance to drive out these bearings as seen in the attached picture ? Is there a trick ? Thanks - Barry [img]https://www.stovebolt.com/ubbthread...59aec122e8a7e04347495c982a8359f&f=49[/img]
