The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 members (greenie-reddy, Herman, glenns towing, 5 Window 9434, Goach2, 1 invisible), 220 guests, and 4 robots.
Forums50
Topics119,938
Posts960,527
Members43,519
Most Online1,229
Jan 21st, 2020
Image Posting Policy
cranks but doesn't start
#1324908 Thu Sep 05 2019 03:35 AM
So I got this '96 Jeep Cherokee XJ that cranks but doesn't start. It's got around 180k on her but I keep everything in good shape. Batt seemed strong.
I used to drive it everyday but this past year I've driven it only about twice a week. It's been just slightly slower to start in the last couple of months, but just barely slower. Was guessing it had something to do with aging plugs or something.
Drove it yesterday and everything was normal like always, sat overnight and today it cranked but didn't catch.
Any ideas on where to start?
Re: cranks but doesn't start
bradleyheathhays #1324910 Thu Sep 05 2019 03:53 AM
Boltergeist
Fuel injected or carbureted? If it's fuel injected, give the bottom of the fuel tank a hard thump with a rubber mallet or a 2X4 while someone holds the key in the "start" position. Sluggish starts, followed by a "crank-- - -no start" condition is a classic symptom of an in-tank electric fuel pump failing. Sometimes you can coax one more start out of it by massaging the fuel tank. If it starts- - - -go directly to a shop that can change the pump- - - -"Do not pass GO- - -do not collect $200.00"- - -and DEFINITELY don't turn the engine off again!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
bradleyheathhays #1324986 Thu Sep 05 2019 09:07 PM
I've run into that on everything from a '69 Datsun roadster to an 89 C10. On the Datsun, it was a dirty screen on the tank sump. I'd simply pull the hose off the intake side of the fuel pump, and blow hard. Then drive off. All until I found the chance to empty, and clean the tank.
So don't rule out a dirty sump. The (in tank) pump may well be OK. smile
Chris
'64 Chev C20 LWB stepside ( Ol'Blue )
[img]http://boltbucket.org/img/OlBlue-C20-badge-64x64.jpg[/img]
bradleyheathhays #1325041 Fri Sep 06 2019 02:26 AM
We had a Chevrolet minivan towed home by AAA. After he dropped it off, he asked what's wrong with it? I told him that it acted like no fuel.
He walked back to his truck and brought a giant, heavy tow hook and crawled under the van. I'm thinking, "what is this crazy old man going to do with that?!"
He tapped on the underside of the tank and said, "OK, start it up." I turned the key and it fired right up!
I am so proud that I didn't say anything to him while he was dragging that giant hook of death under my van.
He said to just replace the fuel pump and you will be good to go. Yep.
bradleyheathhays #1325063 Fri Sep 06 2019 05:05 AM
LOL. That was a great story, Carl. Thanks!
Chris
bradleyheathhays #1325156 Fri Sep 06 2019 09:43 PM
Yeah that was a great story. Good lesson too.
So far I've been able to run a couple tests..
Hooked up a fuel pressure gauge and first key turn got it up to only 20psi. Second turn got it up to 45. And third and subsequent turns got it up to 48. It only fell to 43 after 2 minutes so I think that means the fuel pressure is good.
Hooked up a spark tester between a plug and wire and it didn't light at all when cranked so I'm guessing I've got a spark problem. I'll start by doing a tune up with new rotor, cap, wires and plugs then see what happens. After that it I'll go after the crank position sensor and spark sensor.
bradleyheathhays #1325384 Mon Sep 09 2019 12:51 AM
If you have ever had an MGA you would carry a long-handled screwdriver the pump was behind the passenger's seat and if the ticking stopped you would reach and tap it and usually it would run again. I has an MGA for 49 years and had to do it a couple of times until I replace it with a solid state unit.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Moderated by  Bouncer, Justhorsenround, Tiny
