The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Est2rad customs, 55 SHAKER, 3B, dands, DennisM, 2 invisible), 237 guests, and 3 robots.
Forums50
Topics120,033
Posts961,332
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1952 3100 Sending Unit Screw Size?
#1324963 Thu Sep 05 2019 05:23 PM
ssaxman Offline OP
Would anybody be able to tell me the size and thread pitch of the five screws that secure the sending unit into the tank on a '52 3100? I took one of my screws down to Home Depot and it screwed into both the #10-32 and #12-24 test bolts they had to check screw sizes. It only screwed into the #10-32 about 2/3 of the way until it got tight; screwed all the way into the #12-24 hole, but felt a little loose. I'd like to replace the screws that are currently installed with some nice stainless socket cap screws. Thank you!
Re: 1952 3100 Sending Unit Screw Size?
ssaxman #1324965 Thu Sep 05 2019 05:25 PM
Did you try 10-24? That's likely the correct size.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1324966 Thu Sep 05 2019 05:34 PM
ssaxman Offline OP
Thanks, Klhansen; I did not check #10-24. DOH!
ssaxman #1324984 Thu Sep 05 2019 08:49 PM
ssaxman Offline OP
#10-24 doesn't seem to work either.
ssaxman #1324992 Thu Sep 05 2019 09:24 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Is this an original tank? Many aftermarket tanks are metric threads.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
ssaxman #1324999 Thu Sep 05 2019 10:41 PM
ssaxman Offline OP
Justhorsenaround - no, it's an aftermarket replacement from Classic Parts. I'll check a comparable metric threaded screw and see if that works. Thanks!
ssaxman #1325054 Fri Sep 06 2019 03:08 AM
I had to go check my original and repop tanks.
Both use 10-32 screws for the sending unit. Got my repop from Jim Carter. Made in Taiwan. Box is marked IGM 55A (20171214). I guess I bought it from the right place.
Closest metric size to 10-32 in my tap and die set is 5mm x 0.9. That may be what you need if it's metric.
ssaxman #1325064 Fri Sep 06 2019 05:08 AM
I would just chase each screw hole with a good sharp 10-32 tap and then I'd know what it took.
Evan
ssaxman #1325141 Fri Sep 06 2019 06:08 PM
If the holes are tapped metric, then chasing them with a 10-32 would work, but it would destroy some of the threads (which would be different pitch), increasing the potential to strip the threads in the tank. A 5mm x .9 metric thread would be about 30 threads per inch versus 32. 5mm is 0.197 inch major diameter, versus 0.190 inch for 10-32, so the 10-32 screw would be a bit undersized as well.
I'd try and track down the correct metric screws instead.
ssaxman #1325175 Sat Sep 07 2019 12:56 AM
ssaxman Offline OP
@coilover I thought about doing that, but there aren't many threads there due to the thickness of the tank and I'd hate to get myself up a creek without a paddle, haha.
@klhansen Thank you for the details. I'm going to give the metric screws a shot next time I have the back seat out. It was out this time so I could replace the hose that connects the filler neck to the tank, but that's another story.
Moderated by  Justhorsenround
