The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (klhansen, Canadian_guy, 55 SHAKER, CrowbarBob, 9% grade, Ga92009), 231 guests, and 3 robots.
Forums50
Topics120,033
Posts961,335
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1952 3100 Sending Unit Screw Size?
#1324963 Thu Sep 05 2019 05:23 PM
ssaxman Offline OP
Would anybody be able to tell me the size and thread pitch of the five screws that secure the sending unit into the tank on a '52 3100? I took one of my screws down to Home Depot and it screwed into both the #10-32 and #12-24 test bolts they had to check screw sizes. It only screwed into the #10-32 about 2/3 of the way until it got tight; screwed all the way into the #12-24 hole, but felt a little loose. I'd like to replace the screws that are currently installed with some nice stainless socket cap screws. Thank you!
Re: 1952 3100 Sending Unit Screw Size?
ssaxman #1324965 Thu Sep 05 2019 05:25 PM
Did you try 10-24? That's likely the correct size.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
klhansen #1324966 Thu Sep 05 2019 05:34 PM
ssaxman Offline OP
Thanks, Klhansen; I did not check #10-24. DOH!
ssaxman #1324984 Thu Sep 05 2019 08:49 PM
ssaxman Offline OP
#10-24 doesn't seem to work either.
ssaxman #1324992 Thu Sep 05 2019 09:24 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Is this an original tank? Many aftermarket tanks are metric threads.šŸ›
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
ssaxman #1324999 Thu Sep 05 2019 10:41 PM
ssaxman Offline OP
Justhorsenaround - no, it's an aftermarket replacement from Classic Parts. I'll check a comparable metric threaded screw and see if that works. Thanks!
ssaxman #1325054 Fri Sep 06 2019 03:08 AM
I had to go check my original and repop tanks.
Both use 10-32 screws for the sending unit. Got my repop from Jim Carter. Made in Taiwan. Box is marked IGM 55A (20171214). I guess I bought it from the right place.
Closest metric size to 10-32 in my tap and die set is 5mm x 0.9. That may be what you need if it's metric.
ssaxman #1325064 Fri Sep 06 2019 05:08 AM
I would just chase each screw hole with a good sharp 10-32 tap and then I'd know what it took.
Evan
ssaxman #1325141 Fri Sep 06 2019 06:08 PM
If the holes are tapped metric, then chasing them with a 10-32 would work, but it would destroy some of the threads (which would be different pitch), increasing the potential to strip the threads in the tank. A 5mm x .9 metric thread would be about 30 threads per inch versus 32. 5mm is 0.197 inch major diameter, versus 0.190 inch for 10-32, so the 10-32 screw would be a bit undersized as well.
I'd try and track down the correct metric screws instead.
ssaxman #1325175 Sat Sep 07 2019 12:56 AM
ssaxman Offline OP
@coilover I thought about doing that, but there aren't many threads there due to the thickness of the tank and I'd hate to get myself up a creek without a paddle, haha.
@klhansen Thank you for the details. I'm going to give the metric screws a shot next time I have the back seat out. It was out this time so I could replace the hose that connects the filler neck to the tank, but that's another story.
Moderated by  Justhorsenround
