The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Paul_WNC, D B Cooper, 5253chevyman, BigUglyv1, fonz8261, KevinW), 187 guests, and 3 robots.
Forums50
Topics119,910
Posts960,349
Members43,513
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Cyclone attachment
#1324455 Mon Sep 02 2019 11:42 AM
52_Ton Offline OP
I have been using my shop vacuum to pull the dust out of my media blasting cabinet. This always created the issue of the pre filter in the vacuum being clogged by dust. I ordered a cyclone attachment to add to the vacuum, on Amazon. Works great to separate the dust before it enters the vacuum. I have no tie to this company, just wanted to share a good product. A little pricey for what it is but well worth the time savings of having to blow out the filter.
https://www.amazon.ca/Dust-Deputy-Deluxe-Cyclone-Separator/dp/B002GZLCHM
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
Re: Cyclone attachment
52_Ton #1324470 Mon Sep 02 2019 01:35 PM
Jack of all Trades, Master of None
I bought a top for a 5 gallon bucket from HD for forty bucks. Works great for separating the glass blasting media but the fine dust does seem to get thru after awhile. I bought it mainly for saving the blast media so I could reuse it. Before, the vacuum filter was plugged solid after an hour. Now I can go several days before I need to clean the filter. I do have two filters, so I hose one out and have another to use while the other is drying.
https://www.homedepot.com/p/Dustopp...th-2-5-in-Hose-36-in-Long-HD12/302643445
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
52_Ton #1324501 Mon Sep 02 2019 06:11 PM
ace skiver
Excellent post Phak1.
That is way less expensive that buying a system from a blast-cabinet company.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
52_Ton #1324633 Tue Sep 03 2019 07:15 AM
A couple of great posts!
My solution has always been to tie a t-shirt over the filter in my shop vac. Then it's as easy as shaking the thing out when it gets clogged.
Easy enough to throw the t-shirt in the wash after shaking it out, if it's getting really dirty. smile
In the end, I save a ton of money on shop vac filters. smile
Chris
'64 Chev C20 LWB stepside ( Ol'Blue )
[img]http://boltbucket.org/img/OlBlue-C20-badge-64x64.jpg[/img]
Moderated by  48bigtrucks, MNSmith
