The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
19 registered members (apache3600, Drew54, Builder, 58n63, 2 invisible), 462 guests, and 3 spiders.
Forums48
Topics117,363
Posts938,453
Members42,913
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
width of rear cross member on a 46 chevy #1324508 Mon Sep 02 2019 07:34 PM
sweetpealane Offline OP
I am modifying the cross member by the tailgate on a 46 Chevy with the proper width bed front and tailgate. Previous owner had installed a bed from an AD which measures 56 1/4" across the rear member support . Beds were a little wider on AD's and I need to modify it and redrill the holes that bolt to the bottom of the rear stake pocket. Can someone save me some time by furnishing the magic number .......... that is, the width of an original 46 cross member. I was told several years ago that the bed sides from the AD would work but of course needed the proper width bed front and tallgate so my rear fenders will work with the running boards. When I bought the truck it had an AD bed on it and no rear fenders. Am trying my best to use the original sides.
thanks,
lane
sweetpealane
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324518 Mon Sep 02 2019 08:36 PM
tclederman Offline
Boltergeist
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324530 Mon Sep 02 2019 09:14 PM
couldn't fine the magic number in the oldcarmanualproject piece ........... thanks anyway tim
lane
sweetpealane
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324531 Mon Sep 02 2019 09:14 PM
find the number, sorry
sweetpealane
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324536 Mon Sep 02 2019 10:15 PM
tclederman Offline
Boltergeist
Is the bed width the same as the frame width?
I'm asking/guessing.
http://chevy.oldcarmanualproject.com/chevyresto/4659.htm
48 1/2" outside??, with a 46" rear crossmember?
Maybe someone with a 1946 1/2 ton will post a measurement?
Tim
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324649 Tue Sep 03 2019 12:19 PM
Hey Tim, for sure the width of the bed front and inside measurement of the tailgate is 48 1/2" so the cross member will be a few inches wider because of the way it connects to the stake pockets with the 3 bolts on each side............ i will probably have to set up the bed temporarily and see how the cross member then fits and make my adjustments ........ lazy me, I was hoping to avoid all that as I'm a few months away from actually putting the bed on and am painting those parts as it is easier when it is warm and not wintry ........... maybe someone could go to their assembled 46 and provide the number ............ thank you for your extra thought about the frame width etc [btw-the 56 1/4 is probably just barely wider on the AD rear cross member than an original 46 cross member]
sweetpealane
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324653 Tue Sep 03 2019 12:34 PM
46Sparky Offline
If you can wait until later this afternoon I will get measurements off my ‘46.
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324771 Wed Sep 04 2019 12:36 AM
46Sparky Offline
The sheet metal piece that spans the space between the stake pockets has an overall length of 54 5/8”. The sheet metal overlaps on the backside of the stake pocket face by 2 3/4”, on each end. To be clear, the overlap measurements are included in the overall length of 54 5/8”. The attached photo shows the overlap.
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324861 Wed Sep 04 2019 08:00 PM
just getting back home and to the computer so I missed your post 46Sparky, until now [3pm Wednesday] ............... thank you for measuring that and the photo ...........
lane
sweetpealane
Re: width of rear cross member on a 46 chevy [Re: sweetpealane] #1324863 Wed Sep 04 2019 08:29 PM
46Sparky Offline
Just for grins I measured the bed length at 79 3/4”. I do not know how that compares to the AD models.
Page 1 of 2 1 2
Powered by UBB.threads™ PHP Forum Software 7.7.3
