The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (Swami29, sack, Tommy, D B Cooper, olezippi), 232 guests, and 3 robots.
Forums50
Topics120,034
Posts961,346
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
1950 Burby back door limiters
#1323869 Wed Aug 28 2019 06:39 PM
Moderated
I just picked up a 1950 Burby and it does not have the limiting straps on the rear barn doors. Does anybody know where they can be found (aftermarket or used)?
Re: (NA) 1950 Burby back door limiters
Special FX #1323872 Wed Aug 28 2019 06:49 PM
ace skiver
Post a Parts Wanted ad in the Swap Meet (and look on eBay).
By straps, you are probably referring to the flat bars/stays - "check", used from 1950-1955st?
I have not seen a reproduction for sale.
Question for members:
The parts manual does not show a check listed for 47-49 Suburbans - was the 47-55st Panel door check also used on those early A-D Suburbans?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1323889 Wed Aug 28 2019 09:38 PM
I have a spare set I could be persuaded to let go for a small fortune. PM me please.
1951 Chevy Panel Truck
Special FX #1323890 Wed Aug 28 2019 09:38 PM
ace skiver
Special FX
You cannot send/receive Private Messages until you have made 5 other posts.
Tell us about your truck/project.
Post a few images.
A member might have what you need, but, they cannot contact you. We do not allow person-to-person communication in the forums.
Good luck with your restoration.
Tim
Re: 1950 Burby back door limiters
Special FX #1323924 Thu Aug 29 2019 01:01 AM
There were 2 different styles used with the 2 position props. Which ones do you need ?
Special FX #1323939 Thu Aug 29 2019 02:27 AM
The 2 position are panel only, no?
Special FX #1323945 Thu Aug 29 2019 02:55 AM
I used leather straps on my doors, ala Model A door checks; that's why I have a leftover set of factory originals. I figured these clunky metal things were just another thing to pinch my fingers and bash my head into blush
MNSmith #1324048 Thu Aug 29 2019 05:59 PM
Yes.... the panel vans used the double lock adjusting arms.
Special FX #1324049 Thu Aug 29 2019 06:01 PM
All barn door equipped Suburbans received the single lock adjusting arms.
Mother.Trucker #1324052 Thu Aug 29 2019 06:11 PM
ace skiver
The Master Parts Catalog does not list hinges for the 1947-49 Suburbans, so I guessed those years might have had the same hinges as used on 47-55st Panels?
The different hinge ("single lock") is listed for 1950-1955st Suburbans.
Tim
tclederman #1324054 Thu Aug 29 2019 06:17 PM
I don't know how the rear doors could be attached to the body without hinges but.....as proven many times now....what was printed in the parts books & what was actually done on the assembly line are two different things.
Special FX #1324164 Fri Aug 30 2019 12:51 PM
Bondo Artiste
Great information provided by MT.
The panel truck door upper hinges stops seem readily available. The Suburban only style are harder to find.
Phillip
1927 Chevy Capital 1 Ton truck - basket case
1941 Chevy Suburban - Parts only
1945 GMC half ton truck - Driver
1946 Chevy COE - Might restore one day...
https://photos.google.com/u/1/albums
TrknGMC #1324183 Fri Aug 30 2019 03:20 PM
Not sure you're missing out on much. The stops on my Suburban are so worn that they scratch paint in the closed position. I tired pinging the rivets but they didn't tighten up any.
Special FX #1324199 Fri Aug 30 2019 05:41 PM
Bondo Artiste
I've got a little slop in mine, but I was able to twist the plate, the change the angle, and now it doesn't rub when opening and closing. But I know exactly what you mean.
Phillip
Page 1 of 2 1 2
Moderated by  tclederman
