The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (glenns towing, David C., 51 3804, 1953 panel, olezippi, 1 invisible), 195 guests, and 3 robots.
Forums50
Topics119,927
Posts960,481
Members43,518
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 17" split ring wheel replacements?
lbpa18 #1323822 Wed Aug 28 2019 05:03 AM
Wheel report --
I just last week took delivery from fleabay a pair of 16x6 - 0 offset aluminum wheels listed as trailer wheels. They have 10 cooling holes. I believe you can also get steel wheels of the same description but probably not with hubcap clips. I had been using 16x7 aluminum wheels with a 0 offset and no holes. The 6 inch wheels effectively move the center-line of the tire 1/2 inch closer to the kingpin. It drives so much better I can't believe I put up with it the old way as long as I did. I had the same tires mounted on 8 inch rims and it was almost un-drivable at highway speeds. I only made one 200 mile trip with it like that before putting the 7 inch wheels and tires back on but the 6 inch wheels are the ticket. The original 5 in. wheels have a 7/16 offset as compared with the new wheels 0 in. offset. That apparently gave center point steering. Zero offset is just fine. Negative 1/2 inch is somewhat tolerable and negative 1 in. is probably dangerous once you get tired or get surprised by ruts in the road.
51 3800 PU, 55 235 (w/cam, headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
lbpa18 #1323949 Thu Aug 29 2019 04:12 AM
I'm using 16" Dexstar trailer wheels that I bought from etrailer. Nice black powder coated finish. Was pretty hard to find period correct looking radial tires so I settled for bias plies. Does anyone have a picture of a 3/4 or 1 ton with 19.5 wheels? kind of curious now.
lbpa18 #1323977 Thu Aug 29 2019 12:18 PM
Here's what I can find of mine with 8R19.5 traction tires. If you choose a straight tread 8R19.5 at least for the front they look even more original.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
lbpa18 #1324242 Sat Aug 31 2019 12:19 AM
Those look real good, Grigg. Just right on that truck. Is that a dump box? I'm prepared to be envious.
lbpa18 #1324258 Sat Aug 31 2019 02:31 AM
It is not a dump bed.
I'm slowly in the process of converting to a pickup bed, the first step was swapping the dual wheels and the front hubs out for singles. Sell the bed next (already in swap meet section) and finally restore a 9' pickup bed I already have.
Grigg
Page 2 of 2 1 2
Moderated by  Grigg
