The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (49nut, moparguy, pan3lman, fonz8261, olezippi, 1 invisible), 71 guests, and 3 robots.
Forums50
Topics119,455
Posts956,411
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
46 Chevy Truck hood
#1323371 Sun Aug 25 2019 09:51 AM
Moderated
I have a 46 Chevy truck, it came in pieces. This is my first build and with not seeing how it were dissembled, makes it a little challenging to put back together.The problem I’m having now is I have a 1inch gap between hood and grille. It looked good until I installed the curved hood brace and this is where I’m having the problem. I tried moving fender, raising the cab but nothing seems to work. It seems pretty straightforward how the pieces go back together but something isn’t right. Can someone please help, I’ve been working on this for about 2 weeks.
Distance of v brace center bolts to firewall is 31 7/8
Top of radiator to top of frame is 30 1/2
Center of v brace where it enters firewall to top of frame is 34, due to drop in frame
Nunzio Fiorito
Re: 46 Chevy Truck hood
Piper1106 #1323448 Sun Aug 25 2019 07:06 PM
Can you send a picture?
The crew that works on the \'42 --Sara, Hannah and Abby
Piper1106 #1323476 Sun Aug 25 2019 08:51 PM
Do these help?
Piper1106 #1323487 Sun Aug 25 2019 09:47 PM
It is not clear to me what exactly your problem is, but you can adjust the v-shaped brace that goes from the firewall to the radiator surround. By tightening or loosening the nuts under the dash at the top of the firewall you can move the top of the radiator forward and backward.
That will change the relationship of the front of the hood with the top grill piece.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Piper1106 #1323559 Mon Aug 26 2019 12:35 PM
Originally Posted by Piper1106
I have a 46 Chevy truck, it came in pieces. This is my first build and with not seeing how it were dissembled, makes it a little challenging to put back together.The problem I’m having now is I have a 1inch gap between hood and grille. It looked good until I installed the curved hood brace and this is where I’m having the problem. I tried moving fender, raising the cab but nothing seems to work. It seems pretty straightforward how the pieces go back together but something isn’t right. Can someone please help, I’ve been working on this for about 2 weeks. Thanks
Reading between the lines here, “a 1 inch gap between the hood and radiator”, I wonder if the radiator hoop may be installed incorrectly. What sequence was used for the nuts, washers, bolts, radiator pads and springs in attaching the hoop to the cross member?
Piper1106 #1323578 Mon Aug 26 2019 02:58 PM
Moderated
Distance of v brace center bolt to firewall is 31 7/8
Height top of radiator to top of frame is 30 1/2
Height where v brace enters firewall is 34”, due to dip in frame.
Sits on 92 210 frame.
Nunzio Fiorito
Moderated by  HandyAndy, klhansen
