The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
21 members (59 fleet, buoymaker, baldeagle, cmayna, 2 invisible), 141 guests, and 3 robots.
Forums50
Topics120,502
Posts965,849
Members43,690
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Raising front suspension on '49 3100
#1322841 Wed Aug 21 2019 01:52 PM
Joe S. Offline OP
Dear friends,
I would like to raise the front suspension a couple of inches o my '49 3100 half ton. To me it would look better. Is it simply a matter of getting a couple of steel slabs, drilling them out for the U bolts and pins and inserting them between the front axle and springs?
Will it affect the handling or steering geometry?
Best regards
Joe
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
Re: Raising front suspension on '49 3100
Joe S. #1322846 Wed Aug 21 2019 02:19 PM
Thats one way, or look at the shackles, you maybe able to install longer ones from the rear. My '37 sat low in front, rear shackles were longer and fit right in, raised the front where I wanted without any steering issues.
Joe S. #1322854 Wed Aug 21 2019 03:35 PM
Joe S. Offline OP
Thank you Joe H!
Joe S. #1322878 Wed Aug 21 2019 05:50 PM
I wouldn't do it. There is too much geometry built into the straight axle such as castor, and camber, which will likely be altered by lifting it a "couple of inches". It will also throw your drag link out of wack.
Get yourself a set of LT215/85R16 tires. They will give you a noticeable lift. They measure 30 1/2" tall, compared to the 28" stock tires.
Joe S. #1322886 Wed Aug 21 2019 06:50 PM
Shop Clutterist
I find our old truck feels like it's going to go over when taking a corner that seems like nothing in our Acura. Raising the center of gravity a couple of inches sure won't help! I'm with Carl on this one.
Gord
1954 1/2 ton 235 4 speed
Joe S. #1322946 Thu Aug 22 2019 01:41 AM
Joe S. Offline OP
Thank you Gord&Fran and 52Carl.
Joe S. #1322983 Thu Aug 22 2019 12:32 PM
Boltergeist
It looks like those springs have sagged a little from old age and negotiating too many bumps. Look at the distance between the frame and the rubber bump stops. It's going to bottom out on the stops anytime a serious bounce happens. I'd suggest getting the springs re-arched, adding a leaf, or finding some less-tired springs. Chances are the drag link is already out of level due to spring sag, so a lift MIGHT bring it back closer to right. I'd prefer to restore the suspension to its original condition rather than apply a Band-Aid fix.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1323288 Sat Aug 24 2019 05:12 PM
Joe S. Offline OP
To Jerry aka Hotrod Lincoln,
There is a spring shop 15 minutes away. I have been passing by them for decades and always taken note. Would they be able to look up the specifications for the spring to re-arch them?
Joe
Joe S. #1323289 Sat Aug 24 2019 05:23 PM
Boltergeist
If they've been around awhile they've probably got a gray-headed old geezer who can educate you on spring re-arching. It's a pretty complicated process, and doing it right involves annealing, re-shaping, and re-tempering the spring leaves. I've seen some attempts made at re-arching springs done with a hydraulic press and/or anvils and sledge hammers, with less than ideal results. It's possible that the shop might be able to rebuild your springs with parts they've had on hand for decades, assuming that they have been around for that long. "Talk's cheap"- - - - -drop in and get acquainted!
Joe S. #1323295 Sat Aug 24 2019 05:51 PM
My truck's rear springs were modified during the rebuild in a way that I did not authorize, so they have very little cushioning when going over a bump or hitting a pothole. So when I get back from KC I plan on taking it to a spring shop about 50 miles away to have it fixed, I would like to have the rear end raised 1 inch in the process. The springs are not original because the rear end is out of a 79 Chevy Nova and was custom made for it.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Page 1 of 2 1 2
Moderated by  SWEET
