The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 members (TPR57C, ASU, 5 Window 9434), 76 guests, and 3 robots.
Forums50
Topics119,608
Posts957,782
Members43,442
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1952 3100 Rear Brake Shoes
#1322213 Sat Aug 17 2019 01:36 PM
ssaxman Offline OP
Hey there, Stovebolt gang, this is my first post. I have a 1952 3100 that belonged to my grandpa and was fully restored a few years ago. I noticed some gear oil dripping from the passenger side rear wheel. I removed the drum to find the inside of it and the shoes covered in gear oil. I'm replacing the axle seal and will need new rear brake shoes. I was hoping to source the new shoes locally. I've done some searching, but can't seem to find a part number (other than the original one which wasn't much help) and was hoping someone might be able to help. I found these at O'Reilly's--does anybody know if these are correct for a '52? Many thanks in advance for the help! I'll start a proper "new member" thread in the welcome section once I get this done. Thanks!!
Re: 1952 3100 Rear Brake Shoes
ssaxman #1322225 Sat Aug 17 2019 02:45 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
NAPA is usually your best local option. RockAuto.com is a good online go to and they are offering a discount (see top of General Truck Talk Page) to all Stovebolters until mid-September. šŸ›
RockAuto.com $15 to $34 a set
Last edited by Justhorsenround; Sat Aug 17 2019 02:53 PM. Reason: Added pricing info
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Justhorsenround #1322253 Sat Aug 17 2019 06:33 PM
ssaxman Offline OP
Thank you! I got the ones from O'Reilly's so we'll see how they work out. The replacement axle seal I bought was giving me trouble during installation so waiting on another seal before I can get everything put back together. The only difference between the shoes that were on the truck and the O'Reilly's shoes are that the O'Reilly's linings are the same on both shoes instead of one short lining and one long lining. Other than that, they seem to be identical.
ssaxman #1322265 Sat Aug 17 2019 08:16 PM
With the wheel off, can you feel up and down movement of the axle? Worn bearings/axle shaft will not allow a new seal do its job very long.
Carl
52Carl #1322307 Sat Aug 17 2019 11:43 PM
ssaxman Offline OP
Carl
Thanks for the tip, Carl. I did not check this before removing the axle, but I will when I reinstall. Everything was replaced with the restoration a few years ago, but my aunt and uncle didn't drive the truck very much at all since.
ssaxman #1322329 Sun Aug 18 2019 02:22 AM
The bearings ride on the axle, so it is possible (and common practice) to replace the bearings without checking for wear on the axles. Seals don't like that.
Moderated by  SWEET
