The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Stovebolt is pleased to support the Salvation Army!
We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 registered members (Steelonsteel, agedhorse), 283 guests, and 4 spiders.
Forums48
Topics116,583
Posts930,698
Members42,662
Most Online940
Apr 5th, 2017
Image Posting Policy
engine info #1321671 Tue Aug 13 2019 03:38 AM
Athab3 Offline OP
Hello forum.I recently got a 55 gmc with engine number C440744 and just 3 weeks ago got a 59 1 ton for the cab it has engine number 135762 no letter in front of the numbers..Would like to find out the details,size etc ,of these engines Athab3
Have 55 GMC 9300 short box step side .Needs restoring but starts and drives ,no brakes, also have 59 GMC 9380 with very good cab for parts.have been doing MGA's all mjy life so this is new to me
Re: engine info [Re: Athab3] #1321707 Tue Aug 13 2019 01:51 PM
EdPruss Offline
GMC label their engines with displacement as the start of engine SN, assuming one has a 6, stamped on machined surface aft of starter, on right side, I. e. 228xxxx.
Ed
Re: engine info [Re: Athab3] #1321711 Tue Aug 13 2019 02:23 PM
tclederman Offline
Boltergeist
Athab3,
If someone knows a website (or, has a document) that shows/explains Canadian engine codes (serial numbers, especially), maybe they will offer information/interpretation?
Some/many USA GMC engines have a letter prefix before the number/displacement
I do not know for what years; or, if this is for all years that 228/248/302 engines were made.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: engine info [Re: Athab3] #1321716 Tue Aug 13 2019 02:48 PM
3B Offline
Hy Athab3, Please remember to tell us the size of truck you are inquiring about. If you could post the trucks serial number that would help us decipher just what you have. Canadian light GMC trucks were not powered by GMC engines, they were powered by Chevrolet inline sixes and after the 55B or second series a Chevrolet V8 was an option as well. The largest truck that was available from Chevrolet in Canada up to the 55A or first series were powered by GMC engines the 248 in every one I have seen. In the United States the GMC engine serial number began with the engines displacement, example 248----, 270----, 302----, in Canada the GMC engine engine serial number began with two letters usual G and one other letter. The C in Chevrolet engines serial number I always assumed to designate a commercial engine, just my assumption, hope that helps.
Re: engine info [Re: Athab3] #1321720 Tue Aug 13 2019 03:36 PM
2ManyTrucks Offline
hi Athab3,
unfortunately the stamped Canadian engine serial numbers contain almost no information about the engine.
if you want to identify Canadian engines you need to find the block casting and head casting numbers.
C440744 the C mean light Commercial - likely from a 1/2 ton pickup, is your 55 GMC a 1/2 ton?
does this engine number match the vehicle chassis tag?
post the casting numbers and i'll see what i can find
-s
1430s, 1420, 9430
-2MT
Re: engine info [Re: Athab3] #1321923 Thu Aug 15 2019 03:35 AM
Athab3 Offline OP
OK Ill get those #'s and post them .The 55 GMC is a 1/2 ton and the 59 is a 1 ton dual .Athabs
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
