The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (DennisM, D B Cooper, beltfed, harv, 51sub, Hotrod Lincoln, 1 invisible), 83 guests, and 3 robots.
Forums47
Topics117,757
Posts942,226
Members43,036
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Carb question
#1321653 Tue Aug 13 2019 01:25 AM
JD1 Offline OP
I identified my engine this week with the help of the forum. Thanks guys. I have a 1957 235 with a 1955 head.
I have a single Rochester carb with the stock gas filter and oil bath filter. I have a choke and throttle cable.
I would like to get a new carb and then rebuild my current carb to have as a spare. Can anyone recommend a place to purchase a quality carb that I can use ethenol gas with?
Or would a different carb setup be a better running (less maintenance) carb than the Rochester?
Mike's Carbs has a replacement for the Rochester than looks pretty good, but I don't think I'll be able to use the original gas filter or oil bath cleaner with that carb.
JD
1951 Chevy 3100 1/2 ton (1957 235, 4 speed, 411 rear)
Re: Carb question
JD1 #1321657 Tue Aug 13 2019 01:50 AM
JD--I would get a 32/36 from Langdon's Stovebolt and find non ethanol fuel. I have 2 1954 rebuilt 235 engines, one in a 49 and one in a 51 5 window..the one with the 32/36 purrs like a kitten..all rebuilt..Bill
Re: Carb question
JD1 #1321724 Tue Aug 13 2019 03:55 PM
JD1 Offline OP
Are you running the stock intake, air cleaner, and gas filter?
The only ethanol fuel around me goes for $10 a gallon.
Re: Carb question
JD1 #1321776 Wed Aug 14 2019 01:42 AM
What percent of ethanol are looking to run? Here in the midwest most all the fuel is 10-15% ethanol. I have no problem running 1948 W-1 Carters on this type of fuel.
Re: Carb question
JD1 #1321784 Wed Aug 14 2019 02:21 AM
JD1 Offline OP
It’s usually 10%.
Re: Carb question
JD1 #1321868 Wed Aug 14 2019 07:20 PM
JD1 Offline OP
Are there any opinions on the rebuilt carter yfs from classic Chevy trucks?
Re: Carb question
JD1 #1321871 Wed Aug 14 2019 07:37 PM
Langdon's is a good choice. Here.url=https://www.shop.cliffordperformance.net/68-Chevy-235-261-Combination-68C235.htm]Another choice but expensive.[/url].
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2017 Buick Encore
Pix on Photobucket
Re: Carb question
JD1 #1321970 Thu Aug 15 2019 04:17 PM
We can't give you any encouragement on these because we don't have any idea who rebuilt them, and much worse than that nobody other than the person who worked on them has any earthly idea what parts might be inside them. No idea whatsoever. Unfortunately anybody doing this sort of work can swap parts from any YF into any other YF. The most common problem I've seen is that the float bowl (which carries the identifying marking of the YF model) can be swapped with throttle bodies and air horns of any model YF handy. This creates a mongrel carburetor which will never ever work as it was designed. For this reason alone, I would not buy one of them. Trust me, your money can be spent better elsewhere. Would you like examples? Here are two:
https://tinyurl.com/y5678u2v
https://tinyurl.com/y3fembwo
On both of these, the seller thinks this is a 3211s. It is no more a 3211s than it is a spaceship. No 3211s was ever made with a manual choke. These are guaranteed to be "frankencarburetors" assembled from (a) one 3211s float bowl and (b) throttle bodies and air horns from some other manual choke Carter body. They won't work.
Or this one:
https://tinyurl.com/y2hnwvhv
It claims to be NOS and it may be, but the images are out of focus and it appears to be rusted to the point it will never be ok again.
Over the past couple of years I've gone to great lengths to find as much of the remaining Carter YF information as possible so that any carburetor I have or that I sell can be checked and guaranteed to be what it should be...and it takes a while and some careful study to do this. It most definitely is not the sort of work a wholesale rebuilding operation is ever going to do. They can't afford to do work like that because time is money and their employees are paid based on the number of carburetors they "rebuild" during their shift.
Given your setup I would say you'd do best with a Carter 3211s carburetor although other Carter types might work fine. Are you interested in manual choke or auto choke?
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Carb question
JD1 #1321973 Thu Aug 15 2019 04:46 PM
JD1 Offline OP
I have the stock manual choke and throttle cable.
Re: Carb question
JD1 #1321976 Thu Aug 15 2019 05:22 PM
Thanks...I understand that's what you have now but I was curious as to whether you wanted to keep the manual choke. Going with an auto choke gives you other and more interesting alternatives. The Carter carburetors with manual chokes are at times not easy to find in good and unmolested condition. The 2100s would be the last Carter made for the 235 with a manual choke. I've been looking for one of the 2100s models for a friend, but haven't found any worth buying.
Jon
Page 1 of 3 1 2 3
Moderated by  Woogeroo
