Stovebolt is pleased to support the Salvation Army! We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
Forums48
Topics116,599
Posts930,825
Members42,663
Most Online940 Apr 5th, 2017
Old engine new truck
#1321792
Wed Aug 14 2019 02:43 AM
OP
In need of some help ! Lol. I have a 1959 Apache 31 and am putting a 235 motor in it so I can have the foot starter. I bought a motor the other day and when I got it home I realized that it has side mounts. The motor is a 1954. I’m hoping to not have to change the steering column to make it work. I’m trying to keep it simple if possible. Any help would be appreciated. Thanks ky59apache
Re: Old engine new truck
[Re: Ky59apache]
#1321799
Wed Aug 14 2019 03:16 AM
Well KY, Welcome to the Stovebolt Garage!!! Someone will chime in here and answer your question. I think? I know the answer, but would rather learn from someone that really knows the answer!
Don
Of all the things I've lost in my life, I miss my mind the most!1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt GalleryMore pix on Photobucket'46 2-Ton grain truck '48 3/4-ton grain truck '50 2-ton flatbed '54 Pontiac Straight Eight '70 American LaFrance pumper fire truck.
[Re: Ky59apache]
#1321810
Wed Aug 14 2019 04:14 AM
when I got it home I realized that it has side mounts. The motor is a 1954. Welcome to the Sotvebolt  Your two statements don't go together...you can't have "side mounts" on a "1954 motor", that feature didn't appear on Chevrolet cars until 1958. All 1959 trucks still used the bird leg front motor mounts and the bell housing mounts for the rear regardless of 6-cyl or V8 even though they are cast with the side mount boss'. Your 235 will have two bolt holes on either side of the timing cover that the motor mount brackets bolt to. https://www.classicchevy.com/chevy-...16Ub2yxtDEaAjVNEALw_wcB&gclsrc=aw.dsTo ID your motor, give us the stamped numbers on the machined surface next to the distributor and also the engine casting number found down low, passenger side at the front of the block. Mike B
[Re: Ky59apache]
#1321820
Wed Aug 14 2019 11:15 AM
Welcome, nice to have another 4 eyed truck in the crowd. My 59' was originally a 235 but had a 283 V8 in it when I got it. The 283 had a home built front cradle mount to make use if the in line six mounting point. There where no provisions for side mounts on the frame. The 235 front engine mount is fairly common and shouldn't be to hard to locate. As Mike said your block should be drilled for the front mounts.
Craig
Come,Bleed or Blister somethings got to give!!! Q:"What yah runnin" A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
[Re: Ky59apache]
#1321824
Wed Aug 14 2019 12:22 PM
Welcome KY59. I will be following this thread. I have a 54 3100 and a spare 58 235 engine. I am curious to see what challenges/solutions are identified.
I am fairly close to you. I am in Kenton County KY.
[Re: Ky59apache]
#1321835
Wed Aug 14 2019 02:03 PM
OP
I was told the motor came out of a ‘54 car. I will look for the bombers this evening.
[Re: Ky59apache]
#1321836
Wed Aug 14 2019 02:25 PM
Boltergeist
Some spray-oiler 235's had side mounts as early as 1950, the ones used with Powerglide automatics. I've got a 1950 Chevy Bel Air out back with that setup, and it's currently running a non-original 216, also with side mounts. The steel timing cover plate can be drilled for bird leg mounts and bolted in just like any other 235, or the plate can be changed for one with the mounting holes already there. Changing it is a HUGE job, which involves removing the camshaft. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
[Re: Hotrod Lincoln]
#1321878
Wed Aug 14 2019 08:16 PM
Some spray-oiler 235's had side mounts as early as 1950, the ones used with Powerglide automatics. I've got a 1950 Chevy Bel Air out back with that setup, and it's currently running a non-original 216, also with side mounts. Jerry Can you post a picture of these side motor mounts? I've never seen a pre-1958 block with castings for side mounts! Thanks, Mike B
[Re: Ky59apache]
#1321899
Thu Aug 15 2019 12:06 AM
OP
CON 3. C 14
3835911
These are the numbers I found on the block. It did come with a power glide tranny which will be looking for a new home if anyone is interested! Lol. Not sure how to post pics on here yet. I’ll need my wife’s help with that! Lol.
Dave, maybe we could just trade motors!! Lol.
There are no mounting holes on the front of the block.
[Re: Ky59apache]
#1321913
Thu Aug 15 2019 02:02 AM
3835911 is a 1954/55 235 block casting number. CON 3 is the foundry conveyor number. C 1 4 is the date code...March 1, 1954 The serial number is machine stamped on the smooth machined pad next to the distributor...you may need a wire brush to reveal the numbers...this will tell us if it was born in a car or truck. Mike B
