The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (2ManyTrucks, 66flea, D B Cooper, 1Ton_tommy, bluesman, 1 invisible), 305 guests, and 3 spiders.
Forums47
Topics115,731
Posts919,731
Members42,325
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Info re 55 GMC cab [Re: Athab3] #1321407 Sun Aug 11 2019 03:03 AM
klhansen Offline
Cut the bad one out till you get to good solid metal, then cut the good one to match.
I built a rotisserie for my cab that pivots around the centers of the doors, but you'll probably want to go the "normal" way, pivoting around the front to back centerline.
I think for that repair, I'd consider standing the cab on one side.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Info re 55 GMC cab [Re: Athab3] #1321647 Tue Aug 13 2019 12:49 AM
Athab3 Offline OP
started the cab removal from the 55 frame,rear fenders first then box I think.Athab3
Have 55 GMC 9300 short box step side .Needs restoring but starts and drives ,no brakes, also have 59 GMC 9380 with very good cab for parts.have been doing MGA's all mjy life so this is new to me
Re: Info re 55 GMC cab [Re: Athab3] #1321778 Wed Aug 14 2019 01:53 AM
bartamos Offline
I don't see a reason to spend money/time on a rotisserie for the 59 cab. If you are talking about the inside upper surround, you sit on something like a seat and work sitting. The only possible reason would be for something under cab. In which case, just sit it on it's back or nose. Everything else comes off truck. Rotisserie is a waste of effort for nothing. They are for unibodies/El Camino/cars or possibly serious cab floor/support repair.
Again, if you are doing it for the inside surround, a rotisserie can't give you a better angle than just sitting in the cab on a milk crate.
I hope that you will be able to drill out the spot welds across the top pinch weld and leave the outer pinch weld in place. Then cut where necessary with a .060 thick angle grinder wheel. There may be spot welds under the front of headliner trim. Then it would be just small cuts at the sides to butt weld. With all that rust, it not going to be easy to get a tight butt weld fit up. Removing spot welds will reduce the butt fits greatly. So normally you just cut out the rust, no more. But in this case there are other factors possibly. See what MNSmith says.
Keeping the windshield opening to spec is critical.
FYI: The wheel shown on the 55 is nub style hub cap retention. If you want to be original, keep any wheels you have that have hub cap clips. Nubs are worth keeping also but not correct for your years.
Give'er hell aye?
Laziness is the Father of invention.
Page 2 of 2 1 2
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.3
