The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (den-den, GMJager, Doc.Hall, 5 Window 9434, Hotrod Lincoln, JiMerit Boltr#43), 144 guests, and 3 robots.
Forums50
Topics118,975
Posts952,331
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: 1/2 ton tie rod ends for an AD
Fox #1321146 Fri Aug 09 2019 03:14 AM
Shop Clutterist
If you change the tie rods, you would have to change the tie rod too. I see in the LMC catalog that the '60 to '63 four wheel drive trucks have a similar setup as I have. (as far as tie rod and tie rod ends go)
It was a long time ago that I worked on the chassis, but I seem to remember wondering why my tie rod ends were different than what other people were talking about...
Gord
1954 1/2 ton 235 4 speed
Fox #1321149 Fri Aug 09 2019 03:36 AM
Fox Offline OP
The greatest teacher failure is.
But if the ends have been changed, they must have changed the actual tie rod too. It seems weird also that the trucks I’ve had over these years have had the exact same parts. Something is screwy here, because I have never seen a female ended tie rod end on any of my trucks. My 1 ton has male ended tie rod ends too.
The steering arms on my truck don’t have the ball but the holes only.
I’m guessing as well like Gord, is this a Canadian thing?
Others please share what you have.
As always, I appreciate the help and input fellas.
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
tclederman #1321152 Fri Aug 09 2019 05:08 AM
That's so you can loosen the two clamp bolts and turn the tie rod to shorten/lengthen the tie rod overall length and adjust toe-in.
In the modern type that Fox posted, with male ends, there's usually a sleeve with left and right hand threads to accomplish the same purpose.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Fox #1321156 Fri Aug 09 2019 10:01 AM
My Canadian 44 1/2 ton is exactly as yours is and it was driving me crazy to find new tie rod ends. Thought my steering arms were 3/4 ton since they didn’t have have the straight hole and were tapered to accept the screw in tapered ball stud. Let me know if you find the right tie rod end as I went thru specs of some manufacturers and couldn’t find one short enough.
44 Canadian chevy 1/2 ton
Fox #1321162 Fri Aug 09 2019 11:50 AM
ace skiver
The 1954 Canadian Chevrolet and GMC Maintenance Manual shows the "sealed" tie-rod ends, not the adjustable tie-rod ends used on USA light trucks.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Fox #1321178 Fri Aug 09 2019 02:09 PM
Shop Clutterist
Perhaps the Canadian 1/2 tons used the "heavier duty" tie rod ends as shown in figure 4 here:
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0303.html
Ordering tie rod ends for the (say) 1 tons should fit the 1/2 tons?
Gord
Fox #1321181 Fri Aug 09 2019 02:48 PM
ace skiver
They look to be the same, as Gord suggests.
Does anyone have a Canadian GM truck parts catalog?
Tim
tclederman #1321204 Fri Aug 09 2019 05:08 PM
I have a 42-56 and will check later and post if anyone wants. I remember looking up the part numbers and googling them and could find no images.
Fox #1321325 Sat Aug 10 2019 02:45 PM
Fox Offline OP
Yes, please.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
Fox #1321333 Sat Aug 10 2019 05:11 PM
So the book is 42-56 truck parts catalogue for Canada.
Page 2 of 3 1 2 3
Moderated by  SWEET
