For sale 235 engine, casting 3738307, FI27A on distributor pad. Comes with starter, bell housing, clutch/flywheel, intake/exhaust with Rochester carb, external oil filter. Has water pump relocator plate. Also has Langdon HEI distributor. Can throw in a 12V generator, but missing the mounting bracket.
Runs, burns a little oil, compression 105-110#. Needs rear main rope seal.
Asking $250 OBO, Will consider parting out. located in Butler, PA 16001.
Jon
