The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (54farmtruck, 55 SHAKER, Denny Graham, Eisenhart1992, 2 invisible), 142 guests, and 3 robots.
Forums50
Topics119,015
Posts952,750
Members43,313
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1942 3/4 Ton Ring & Pinion Swap
#1320870 Wed Aug 07 2019 02:51 PM
I've installed T5 in my 42 3/4 ton Chevy (running a 1962 235 6 cyl). While this is a major improvement over the OE Muncie 4 speed, it still leaves some things to be desired. The 3/4 ton's stock 4.55 R&P set makes 1st gear pretty useless although, the truck is far better at highway speeds. I'd like to swap out the R&P set to something closer to 3.90 or 4.10, in order to take care of the low speed acceleration. Can anyone tell me if they've done this in an Art Deco 3/4 ton? I did read the tech article about the 1955-62 pumpkin swap but, why change the whole pumpkin & mod the driveshaft just to swap the R&P ratio? If a replacement gear set in the 3.90 or 4.10 ratio is available for the 41-46 3/4 ton, I'd sure like to know about where to get a set. Thanks for any help or sources you have.
Ghost Rider
Little Egg Harbor, NJ
1942 Chevy 3/4 ton pickup
Re: 1942 3/4 Ton Ring & Pinion Swap
Ghost_Rider #1320890 Wed Aug 07 2019 04:49 PM
Boltergeist
Running a T-5 in a 3/4 ton defeats the purpose of having a truck, so you might as well install some type of passenger car rear axle, also. High ratio gears for your stock rear end don't exist.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Hotrod Lincoln #1320929 Wed Aug 07 2019 09:55 PM
I have all of the OE driveline on the shelf. I just got tired of being limited to 45 mph. BTW, the T5 came out of an S10, and it serves my purposes quite well. I'm not pulling stumps anyway.
Ghost Rider
Ghost_Rider #1321150 Fri Aug 09 2019 03:45 AM
Found a 4:11 ratio pumpkin from late 60s that dropped right into my 53 3600, not sure if same holds true for your 42. Late 60s 3/4 tons with automatic trans came with the 4:11s.
Best of luck
1946 1/2-Ton Chevy
Moderated by  SWEET
