The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (1956 3200, DennisM, 55shaker, 3B, 2ManyTrucks, 3 invisible), 127 guests, and 3 robots.
Forums60
Topics124,935
Posts1,008,311
Members45,097
Most Online1,229
Jan 21st, 2020
Image Posting Policy
216 and 235 manifolds the same?
#1320790 Wed Aug 07 2019 12:34 AM
Skooter Offline OP
Just wondering if a 235 manifold assembly would fit my 216.
2 Chronicles 7:14
1952 Chevy 1/2-ton 3100
Dalton Highway survivor
www.truckwithaheart.com [flickr.com]
Re: 216 and 235 manifolds the same?
Skooter #1320801 Wed Aug 07 2019 12:59 AM
Bubba
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Skooter #1320815 Wed Aug 07 2019 02:07 AM
The bottom of all 216 intake manifolds are flat. The early 235 intake manifolds are also flat, and as far as I can recall are the same as the 216.
Identifying that the bottom is flat may be of more real-world use for you, given that parts get change around a lot over the many decades.
Tim's post has the casting numbers which can be used to narrow things down once you get your hands on a flat bottomed intake.
Skooter #1320872 Wed Aug 07 2019 02:57 PM
1941-49 216 and 235 manifolds are exactly the same (1941 is the first year for a 235).
These have the connection for the head pipe exiting straight down.
1949-53 216 manifolds have the head pipe connection angled towards the rear.
1950-62 235 manifolds also angle towards the rear, but have slightly larger ports where the manifold bolts to the head. They also use larger alignment rings to match the larger ports.
1950-62 235 manifolds can be used on a 216 but the alignment rings will do little to align the manifold, unless stepped rings are used.
My Blog
Skooter #1320908 Wed Aug 07 2019 06:59 PM
Skooter Offline OP
Thanks for the info. Don't believe manifold I was looking at will work.
Mostly just need to repair my enlarged heat riser shaft holes but dread taking old manifolds apart for fear of breaking the bolts.
2 Chronicles 7:14
Skooter #1320912 Wed Aug 07 2019 07:41 PM
Heat, penetrating oil, and patience is the key to getting those manifolds separated. Once they're apart, ALWAYS change the studs and bolts before reassembling.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
