The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (KEVINSKI, Just Mark, 55 SHAKER, hapydirty, '54 3600, 1 invisible), 277 guests, and 3 spiders.
Forums47
Topics115,730
Posts919,728
Members42,325
Most Online940
Apr 5th, 2017
Image Posting Policy
Can you ID this motor #1320025 Thu Aug 01 2019 11:33 AM
David C. Offline OP
Vintage Truck & Tractor
Current project; 1961 C20, 235 I6
Re: Can you ID this motor [Re: David C.] #1320026 Thu Aug 01 2019 11:37 AM
tclederman Offline
Boltergeist
laalaaWell, I'd bet that it is not a 1951 Chevrolet truck motor.nono
But, it is a freebie.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Can you ID this motor [Re: David C.] #1320027 Thu Aug 01 2019 11:52 AM
TUTS 59 Offline
Looks like a late sixties 261, the valve cover is similar to a 292. No HEI and PCV and later style air cleaner are some clues. But like im said "Free is free".
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
Re: Can you ID this motor [Re: David C.] #1320028 Thu Aug 01 2019 12:04 PM
tclederman Offline
Boltergeist
It is most likely a 230 or 250 (see image below)
It is not a 261 (which were produced from 1954-1962/63).
Originally Posted by TUTS 59
Looks like a late sixties 261, the valve cover is similar to a 292. . .
Maybe someone knows 292s?
Last edited by tclederman; Thu Aug 01 2019 12:16 PM. Reason: I added a 250 and 292
Tim
Re: Can you ID this motor [Re: David C.] #1320029 Thu Aug 01 2019 12:16 PM
tclederman Offline
Boltergeist
See above, the 292 has a different valve cover?
Tim
Re: Can you ID this motor [Re: David C.] #1320030 Thu Aug 01 2019 12:17 PM
EdPruss Offline
292 pushrod covers are about 6" tall, easy to distinguish from smaller engines.
Ed
Re: Can you ID this motor [Re: David C.] #1320038 Thu Aug 01 2019 12:57 PM
Hotrod Lincoln Offline
Boltergeist
230 and 250 engines use the same block casting and bore size. The only difference is the crankshaft. You'd need to check the stamped number by the distributor to get a good identification.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Can you ID this motor [Re: David C.] #1320055 Thu Aug 01 2019 03:52 PM
Wrenchbender Ret. Offline
Its a 250 from 68 to 74. Probably from a car. It has a Mono-jet carb 68 up. The air cleaner is a car type. The point type dist was dropped after 74.
George
1956 Chevy 1/2-Ton Pickup
Re: Can you ID this motor [Re: David C.] #1320639 Tue Aug 06 2019 01:56 AM
glenns towing Offline
250 ci from 73 to 76 is what a really quick google check discovered
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
