The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (3B, Harold46, 49nut, 55_2nd_Series, Johnny N, 1 invisible), 129 guests, and 3 robots.
Forums50
Topics119,431
Posts956,226
Members43,401
Most Online1,229
Jan 21st, 2020
Image Posting Policy
'57 Transmission fluid question
#1317818 Mon Jul 15 2019 07:59 PM
I've recently picked up a '57 Apache, and I'm getting ready to replace the transmission fluid, and wanted confirmation I was looking at the right spot for the refill.
Can anyone please confirm in the attachment the red arrow is pointing to the fill plug hole, and SAE 90 is the right fluid? Looks like 6.75 pts?
If I'm right and that is the spot - seems tedious to get that filled up, any best practices to ensure I don't end up with transmission fluid all over my garage instead of in the truck would be appreciated.
Re: '57 Transmission fluid question
Terrance57 #1317853 Mon Jul 15 2019 11:51 PM
That is the fill / fluid level plug. You can pop the shift lever out & pour fluid in top.
BC
1960 Chevy C10 driver 235 T5 3.73 dana 44
1960 C60 pasture art
G.M dealer tech since 1980 & counting
Terrance57 #1317855 Mon Jul 15 2019 11:57 PM
ace skiver
SM420 4-speed
Fill to the hole level, if topping up having warm oil in the transmission.
Fill to about 1/2” below the hole level, if adding all new/cool fluid to the transmission (or, 6 pints, supposedly).
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0005.html
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Terrance57 #1317871 Tue Jul 16 2019 01:40 AM
Thank you for the responses!
Terrance57 #1318321 Fri Jul 19 2019 01:18 AM
You should be able to buy the correct fluid in a 2 quart size container that has a small spout that fits easily in the filler hole. Just squeeze it in until it starts to run out the hole. If you are replacing the entire fluid, it will just take a while.
Lee.
1956 Chevy 3200, 235 w/3 speed
Moderated by  SWEET
