The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (BigBlockMan, Britcon, Barnfind49, carryall jerry, DennisM, 3B), 305 guests, and 3 spiders.
Forums47
Topics115,216
Posts915,254
Members42,199
Most Online940
Apr 5th, 2017
Image Posting Policy
Inner fender bolts #1317401 Thu Jul 11 2019 08:48 PM
Montana 54 Chevy Offline OP
54' 3600. Im pulling the fenders off and the inner one has these bolts here. Are these accessed from in the Cab? If so mine are just spinning and going nowhere. Anyone hot any tips on how to access these?
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317402 Thu Jul 11 2019 09:06 PM
klhansen Offline
They are accessible from inside the cab. Those rectangular nuts in your photo are welded/staked to the inner fender. They don't appear to be spinning or loose in your photo, though. If you can, you might consider snapping the heads off them, and deal with the weld-on nuts and remnants of the bolts once the inner fender is off. Replacement weld nuts are available from McMaster-Carr or other suppliers.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317413 Thu Jul 11 2019 09:30 PM
tclederman Online
Boltergeist
Kevin's advice is good.
However, I believe in prayer and swear, and in good luck.
Before breaking-off/snapping-off the bolt heads:
- Try a lot of penetrating oil on the threads that show, and around the heads.
- Wire brush the threads a few times.
- Then, see if you can loosen the bolts.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317424 Thu Jul 11 2019 10:41 PM
Justhorsenround Offline
Grease Monkey
Do as Tim suggested but instead of trying to remove the bolt try tightening in just a tiny bit. Many times that motion will loosen the bolt and allow you to remove it.
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317433 Fri Jul 12 2019 12:14 AM
klhansen Offline
But he said the bolts were spinning, indicating that the bolt or nut threads are completely stripped, although the pic doesn't indicate that (maybe it was a "before" shot). ohwell
Both Tim and Martin's suggestions are good if the threads are frozen. Tighten and loosen as Martin suggested sometimes works, although by a couple of cycles, I usually find the head in the socket with the threads still engaged in the nut. In this case, it would at least get the truck apart. On my truck, the floorboard (or lack thereof) allowed the inner fenders to come loose. I did have to re-weld a couple of the weld-on nuts.
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317449 Fri Jul 12 2019 03:03 AM
52Carl Offline
If original, the heads should take a flat screwdriver. This creates a problem since you can't apply much torque to those type of screw heads. It really isn't necessary for these bolts to have that kind of head since the thick, spongy padding under the floor mat will easily hide a hex head even with a washer under it.
Grind the heads off with an angle grinder, then take the inner fender to the bench where you can more easily spray them with Kroil or similar, or apply heat to the captured nut, and so that you can get vice grips on the exposed threads (visible in your pic) and easily unscrew them.
Carl
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317453 Fri Jul 12 2019 03:21 AM
klhansen Offline
The bolts holding the inner fenders to kickboard on my truck were hex, and I'm pretty sure they were original. The LF fender was replaced but the right was original.
But either slotted heads or hex can be ground off like you suggest. Much easier to work on stuck bolts when you're not laying on your back underneath or trying to squeeze under the dash.
Re: Inner fender bolts [Re: Montana 54 Chevy] #1317493 Fri Jul 12 2019 02:09 PM
EdPruss Offline
Heat, as mentioned above, will allow almost any bolts to be taken out, IF it can be done safely. Get the bolt red, let it cool off, then remove.
Ed
Moderated by  Fourbrads, HandyAndy
Powered by UBB.threads™ PHP Forum Software 7.7.2
