The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (BigBlockMan, Harold46, Barnfind49, 55_2nd_Series, 2 invisible), 278 guests, and 3 spiders.
Forums47
Topics115,267
Posts915,649
Members42,211
Most Online940
Apr 5th, 2017
Image Posting Policy
Rear axle swap ??? — 1955-59 Chevrolet 1/2 Ton Pickup Chassis #1317316 Thu Jul 11 2019 04:06 AM
Kilted54 Offline OP
Need a rear axle swap or just the 3rd member? I hear this is a good way to go! I will find out soon as I recently bought a 55 3100 axle
https://www.ebay.com/i/192533882028...wfQixQFFAqJT7PUCbsrx08N1UqxoCFtUQAvD_BwE
Re: Rear axle swap ??? — 1955-59 Chevrolet 1/2 Ton Pickup Chassis [Re: Kilted54] #1317321 Thu Jul 11 2019 07:35 AM
tomctomc Offline
the frames on the 58/59 are longer than 55-57 ones. the rails can be shortened for the earlier years. just something to keep in mind if the intent is to use this 59 frame on a 55-57 truck.
Re: Rear axle swap ??? — 1955-59 Chevrolet 1/2 Ton Pickup Chassis [Re: Kilted54] #1317346 Thu Jul 11 2019 01:02 PM
Kilted54 Offline OP
For the longest time I was looking for an axle which is on this frame. I read that you can pull the third member out and put in Tourque tube axle converting it to open.
People may want to read (because I’m not an expert):
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/995906/1.html
No bolt pattern changes, no worry abt width, great gear ratio when combined w/ some T5 trannies( like one I have that is waiting) for keeping these 6 bangers in the rpm range ....
Never thought abt frame swap so thanks for adding for those who might consider!
Re: Rear axle swap ??? — 1955-59 Chevrolet 1/2 Ton Pickup Chassis [Re: Kilted54] #1317380 Thu Jul 11 2019 05:13 PM
BC59 Offline
Take a closer look at the last 2 photos, this is a Spicer 44 axle. doesn't have a 3rd member. Used mostly in GMC.
BC
1960 Chevy C10 driver
Re: Rear axle swap ??? — 1955-59 Chevrolet 1/2 Ton Pickup Chassis [Re: Kilted54] #1317430 Thu Jul 11 2019 11:44 PM
Kilted54 Offline OP
Good spot as I type red faced!
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.2
