The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (bluesman, cdandelivery, KEVINSKI, drdoug, Greg Brown, 3 invisible), 261 guests, and 3 spiders.
Forums47
Topics115,204
Posts915,152
Members42,197
Most Online940
Apr 5th, 2017
Image Posting Policy
Horn Wire #1317035 Tue Jul 09 2019 12:08 AM
rickmg Offline OP
What is involved to replace the horn wire from the steering wheel to outside the bottom of the steering mast on a 1939 Chevy truck? Mine is bare at the bottom of the steering mast and shorting out.
Rick
Re: Horn Wire [Re: rickmg] #1317041 Tue Jul 09 2019 12:41 AM
52Carl Offline
I had that problem with my '50. I slid a short section of heat shrink tubing over the end of the horn wire up through the hole in the mast. I then applied some heat to the portion of the tubing which was outside of the mast to hold it in place. It worked like a champ.
I am guessing that the only part of the wire which was missing insulation was close to the hole in the mast.
It was worth a shot to try the heat shrink tubing fix. If that had not worked, I would have had to order a pricey new mast bearing which comes with a new wire, and pull the steering wheel and the old bearing. I do not know if the '39 has the same design for the mast bearing/horn wire.
Carl
Re: Horn Wire [Re: rickmg] #1317054 Tue Jul 09 2019 02:09 AM
rickmg Offline OP
You are correct Carl. The wire is bare where it comes out of the mast. I'll give your heat shrink tube fix a whirl the next couple of days.
Rick
Re: Horn Wire [Re: rickmg] #1317103 Tue Jul 09 2019 05:00 PM
tomctomc Offline
whenever you need to replace an old wire that is concealed or routed through an inaccessible space, a useful technique is to connect the new piece to the old (by twisting, tying, soldering, etc) and use the old wire to pull the new one through...
Re: Horn Wire [Re: rickmg] #1317153 Wed Jul 10 2019 12:43 AM
52Carl Offline
Rick,
Does the bare wire against the hole in the mast make the horn honk? It should, I think. You definitely need to fix the bare wire, but if your horn isn't currently working, you may have another issue besides the bare wire.
Carl
Re: Horn Wire [Re: rickmg] #1317172 Wed Jul 10 2019 02:20 AM
rickmg Offline OP
The wire is bare at the hole in the mast, completing the circuit and causing the horn to blow. Does it both the city and country horns. Another thought I had was to drill a hole a couple of inches above the existing hole. Capture the electrical line below, pull it through the new hole, repair it, and draw it back through the original hole. Going to try the shrink tube method first. Hopefully tomorrow. Went fishing with a friend today instead of working on the horn.
Rick
Re: Horn Wire [Re: rickmg] #1317551 Sat Jul 13 2019 01:57 AM
rickmg Offline OP
Update on the horn wire. Looks like it is shortening out not too far under the steering wheel. No short cut for that.
Rick
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.2
