The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (canuck49, KEVINSKI, 5 Window 9434, 1958_Apache, greenie-reddy, 1 invisible), 185 guests, and 3 robots.
Forums50
Topics120,964
Posts969,728
Members43,804
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Throttle linkage for 52’ 3100 w/59’ 235’
#1316274 Tue Jul 02 2019 02:02 PM
Phak1 Offline OP
AD Addict
I’m trying to identify what throttle linkage will work with my 235 transplant. The existing linkage kinda works but isn’t correct as you can see in the photos. The return spring is not in line with the bell crank, stretched at angle away from the engine and attached to a bracket at the bell housing. My engine has the second hole for the bell crank behind the exhaust. Any ideas and pictures would be greatly appreciated. Thanks in advance.
Phil H
Phil
1952 Chevrolet 3100
Project Journals
‘59 235 & hydraulic lifters
“Three on the Tree” & 4:11 torque tube
12v w/ Alternator
Re: Throttle linkage for 52’ 3100 w/59’ 235’
Phak1 #1316375 Wed Jul 03 2019 01:21 PM
Phak1 Offline OP
AD Addict
Does anybody know what this linkage came from?
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Phak1 #1316381 Wed Jul 03 2019 03:32 PM
I fasten the spring back on the petcock close to the bell housing.
1946 1/2-Ton Chevy [stovebolt.com]
1953 Chevy 3/4-ton Factory Stakebed [stovebolt.com]
Phak1 #1316622 Fri Jul 05 2019 02:56 PM
Phak1 Offline OP
AD Addict
Thank you JiMerit for your info. The existing setup is cobbed together. The vertical rod to the carb actually rotates over center of the bellcrank (past the pivot point) and I’m afraid of it getting stuck while driving. It appears from the illustration you posted, that the existing linkage may have come from a car. That is likely as the engine came from a 59’ car. I think the only way to solve the issue is to purchase 52’ 216 linkage and return everything basically back to stock.
From what I have gathered from this forum and links from it, to fix it I need to use the existing linkage from a 52’ 216, move the pivot point forward a few inches to the second mounting point. The shorten/lengthen the pedal rod to fit.
Am I on the right track?
Phil
1952 Chevrolet 3100
Project Journals
12v w/ Alternator
Moderated by  Woogeroo
