The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (coilover, David C., CJ57, Dcurtis, drdoug, D B Cooper, 1 invisible), 287 guests, and 3 spiders.
Forums47
Topics115,175
Posts914,903
Members42,193
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #924576 Sun Mar 03 2013 08:58 PM
Sedgewick Online
Not all handles have the two screws. They may have at first but were either removed or got lost. I only have one per handle.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1030103 Wed May 21 2014 01:27 AM
PaPa Joe Offline OP
I realize it has been awhile... but I thought I would update this thread. I ended up cutting the door handles off. big_eek Someone had used epoxy to keep the handles from coming loose. nono It worked very well! They definitely were not going to come loose! smile So I had to buy two new door relays and handles. ohwell But I have no problem opening or locking my doors now. thumbs_up
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315388 Sun Jun 23 2019 02:24 PM
5 Window Jim Offline
Moderated
I have a 1952 3600. I ordered and received new door relays for both doors because the splines on the shaft are worn and the handle will spin freely on the shaft (I have to open the door using the outside handle now). The new ones look the same as the originals. The problem is one of the three screws holding the mechanism onto the inner door panel is covered up by the pivot for the relay arm (see the attached image). How do I remove this screw?
Door relay.jpg (83 downloads)
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315513 Mon Jun 24 2019 11:40 AM
HandyAndy Offline
Jim,
Using an old handle or pair of vise grips, operate the door relay and you'll have access to that screw!
Andy
His: 1947 Chevrolet 3100
Hers: 2008 American Saddlebred
"I may not have gone where I intended to go, but I think I have ended up where I needed to be." - Douglas Adams
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315536 Mon Jun 24 2019 02:19 PM
JD1 Offline
You have to move the pivot arm back towards the door. Sometime this pivot arm won't move because the latch sticks. You can loosen the bolts on the latch and move that a bit so you can get to that screw holding the remote on.
1951 Chevy 3100 1/2 ton (1955 235, 4 speed from a wrecker)
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315553 Mon Jun 24 2019 05:52 PM
MNSmith Offline
I've always used an open end wrench. Loosen it, remove the accessible bolts, spin the assembly to clear the hidden bolt, remove bolt.
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315715 Wed Jun 26 2019 02:10 AM
Moderated
Andy, I understand what you are saying and I think that should be the normal way to do it. I can get the arm to move but not enough. It still has the original clutch head screw so I need to be able to get good access to it with my driver. I will try JD1's suggestion to see if I can get the pivot to move back toward the latch side of the door. I sure to not want to have to take the latch out completely. Thanks to Andy, JD1, and MNSmith for your help. I'll let you know how things go when I have a chance to get back to the task. By the way, here is an image of the vehicle in question.
1952 3600.jpg (38 downloads)
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1315833 Thu Jun 27 2019 05:47 PM
MNSmith Offline
Sorry, I completely forgot that the original screws were clutch head. I always replace mine with regular bolts for serviceability.
Re: 1953 3100 - interior door handle removal? [Re: PaPa Joe] #1317581 Sat Jul 13 2019 12:25 PM
HandyAndy Offline
Jim,
Were you able to remove those screws and get your new door controls installed?
Andy
Page 2 of 2 1 2
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.2
