The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (Hambone, tclederman, dougs, 1 invisible), 190 guests, and 3 robots.
Forums50
Topics121,036
Posts970,304
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Get Help / Borrow Tools
treydrummer #1315098 Fri Jun 21 2019 03:05 AM
My Dad did that to me when I was really young!
He would shut off a running lawn mower by shorting the plug to the frame with his hand.
To this day, I can't stand to be shocked.
Don
Edit: He also tole me when he was a teenager back in the 30's.
The boys would see who could kill a running four cylinder Model T by shorting out the plugs with their fingers.
No wires removed, Just ground the plugs out with your fingers.
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s893.photobucket.com]
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
treydrummer #1315110 Fri Jun 21 2019 10:41 AM
Grigg/We B Old you guys got me a lot closer than I've been in weeks. I ran a 12g wire from the positive battery terminal directly to the coil. Turned it over and it started belching and farting. WAY more response than I've gotten since i last drove it. So from that I'm taking that the new battery cables i installed are too thin and my timing is now off from me fiddling with it.
I got a buddy who builds hotrods that says he's got 6 feet of cable in his garage. So hopefully I can get it back on the road by this weekend.
treydrummer #1315149 Fri Jun 21 2019 05:07 PM
ODSS Lawman
Trey
Where do you live?
SWEET
Sergeant At Arms
Old Dominion Stovebolt Society
BUNS?!?!?! Where we're going, we don't need no buns.....
1950 GMC 450 (25% owner)
1951 Chevy 1/2-Ton
The GreenMachine
SWEET #1315150 Fri Jun 21 2019 05:16 PM
Churchton It's between Shady Side and Deale 20 min south of Annapolis and Edgewater
treydrummer #1315247 Sat Jun 22 2019 02:28 PM
Sounds like the ”Engine whisperer” is now on the case. If it can be started, it will come alive!
Chris
treydrummer #1316206 Mon Jul 01 2019 09:14 PM
I would check the condition of the points. The "No Fire" makes me think that the distributor is not grounding the coil. Inspect the condition of the contact on the points. I would just file them and set the gap and then see if I could get the engine to fire.
treydrummer #1316638 Fri Jul 05 2019 05:34 PM
I swapped out the points and condenser. Then I had no spark. Put the old ones back in. Now I have spark. What gives
I need to find someone local who can come in here and start this darn thing. I'm missing out on the whole summer
treydrummer #1316649 Fri Jul 05 2019 07:01 PM
Clean the brand new points. They often come with some type of crap on the contacts.
Another cause could be the wire between the coil and the distributor. The copper inside the wire can fatigue over time from the frequent movement of the distributor via the vacuum advance.
treydrummer #1316652 Fri Jul 05 2019 07:30 PM
Thanks I'll check. But I'm getting good spark now but it's not kicking over. I'm getting to be at my wit's end
treydrummer #1316658 Fri Jul 05 2019 08:26 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Fuel, fire, compression each at the right time. You say you have the fire. You’ve poured fuel down the carburetor, so you have fuel. That leaves compression and timing to check.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Page 2 of 3 1 2 3
Moderated by  amtrakjoe, Bill Marlow, SWEET
