The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (66flea, DennisM, 51 2 Ton, Flatblu4748, 53 green 1- ton, 1 invisible), 186 guests, and 3 robots.
Forums50
Topics118,977
Posts952,350
Members43,300
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
rear window rubber
#1314547 Sun Jun 16 2019 10:19 PM
Well, I finally got my rear window installed. I haven't put the lock strip in yet, but at least the glass is in place.
The oly thing I can see as a problem at the moment is the fact that the rubber doesn't bend well around the corners. I don't know what the problem is. Is the glass not seated properly? Is the rubber somehow distorted? Will the rubber settle in after I get the lock strip in?
Anyone else have this problem? And if so how did you deal with it?
I'm attaching a couple of photos to show what I mean.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Re: rear window rubber
bluesman #1314571 Mon Jun 17 2019 01:41 AM
Time and summer heat should make that lay down. You could also try stretching it tighter in those corners with your fingers (looks like you have sealer in the channel which may not allow it to move however).
I like the color of your truck.
1951 Chevy Panel Truck
bluesman #1314581 Mon Jun 17 2019 02:40 AM
There is a bead of butyl rubber holding the channel to the metal pinch weld, no sealant in the glass channel (yet). I'm thinking of hitting it with my heat gun, then taping it down while it's soft and letting it set up that way.
I like the color, too! It's called Burgundy Maroon, and was only offered in 1953,
Tim
Tim
bluesman #1314610 Mon Jun 17 2019 01:28 PM
Tim,once the lockstrip goes in it will help,your suggestion of the heat gun will help too but just go easy with the heat,yours don't look too bad
Claytonrite rubber,the type used in the rear windows is available in many different sizes,some of the wider profiles do tend to pucker in the corners and the small radius plays a part too.
More pix on Flickr .
bluesman #1314708 Tue Jun 18 2019 01:57 AM
I don't use any sealant whatsoever on back glass. The locking strip will create a water tight seal.
bluesman #1314910 Wed Jun 19 2019 08:05 PM
If it doesn't lay down on its own, I have carefully notched it with a sharp razer blade and sealed the cut with black RTV. Not really proud of this fix, but it works. In my experience, its tough to get things perfect on older vehicles due to differences in the thickness of modern glass and the rubber is always quite the same as the original. John
bluesman #1315035 Thu Jun 20 2019 04:01 PM
I just did this last week. Looked the same as yours untill I installed locking bead, then all good. Side note, I used nylon pry bars from harbor frieght to install bead.
54 truck
bluesman #1316788 Sat Jul 06 2019 07:36 PM
Update on the rear window.
I spent a couple of days trying to get the lock strip in, but could only get it started and about one foot before the tool slipped out of the channel. And I couldn't get it back in with the lock strip in place, so I would have to start over.
I finally went to my local O'Reilly's and bought a different tool. It's a Lisle 47000 tool, with four different sized tips that are interchangeable, and MUCH thinner than the tool I bought from Jim Carter. Also has a much better handle, sort of like a large screwdriver, which made it easier to hold and apply pressure. Tried it out this morning and the lock strip slid right in. Much easier to work with the thinner tool, goes into the channel easily, slides with next to no friction. And it was only $17.
Amazing what having the right tool can do.
Tim
Tim
bluesman #1316796 Sat Jul 06 2019 08:25 PM
In case you need one, Home Depot & Walmart sell the Lisle 47000 tool.
www.homedepot.com $13.32. Free ship to store
www.walmart.com $13.32 Free ship to store
It is a great tool to have in your tool box.
Harold
Harold
bluesman #1316797 Sat Jul 06 2019 08:44 PM
ace skiver
How does it (on the left) compare in functioning to the 48600 (on the right)?
That offset arm might be handy/helpful?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Page 1 of 2 1 2
Moderated by  HandyAndy, klhansen
