The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (1953 panel, buoymaker, GarlandFarms, beltfed, HandyAndy, 2 invisible), 359 guests, and 2 spiders.
Forums48
Topics116,551
Posts927,165
Members42,470
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
1952 GMC Dump..... #1314420 Sat Jun 15 2019 04:29 PM
Brian_Ostner Offline OP
Been watchin this dump truck for a few years now.....
Have the opportunity to pick it up st a relatively reasonable price.
Has zero rot. All completely there.
Very nice condition....
I have 6 brand new tires for it in my shop....
Does anyone here know if its a 1 ton or bigger?
Has a 292 engine with 4 speed tranny.
Didnt look to see if it had a 2 speed rear...
Value?
Brian
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314421 Sat Jun 15 2019 04:45 PM
Grigg Offline
292 wouldn’t be original.
What size truck, 400 series or one smaller?
1952 Chevrolet 3800 pickup
---All pictures---
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314422 Sat Jun 15 2019 04:51 PM
I dont know what series....
Motor looks to be original...
I just assumed it was a 292...
I was only there for about 15 mins then had to leave.
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314428 Sat Jun 15 2019 07:10 PM
Elderly Iron Offline
Maybe it's the camera angle, but that appears to have the long nose on it. I've seen where the long nose trucks (Fire trucks, more specifically) had the 503. That and Detroit diesels. If that's not a long nose, then I'm out! Other than that, next time you go by, clean off the flat area on the block just behind the distributor. The first 3 numbers should be the CID
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314429 Sat Jun 15 2019 07:13 PM
Thanks for the tip.
Will check out those #’s.
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314482 Sun Jun 16 2019 04:03 AM
EdPruss Offline
Not large enough for a 503. 194,230,250, 292 all look different than GMC engines, although about the same length. GMC valve covers are rounded on top with no length wise marks. Chevies have some kind of lengthwise marks. If it is a 292, the pushrod cover is about 6" high. Show a picture.
Ed
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314526 Sun Jun 16 2019 06:11 PM
spanky Offline
You may have hit the Jack Pot with that one. Can't tell for sure, but it looks to have Dayton wheels on it, and the larger, flared out wheel well fenders, of a 400, 450, or 470 series truck. It has vent door glass, so if it's a 51 model, with pull down door handles, it will have a 270ci. GMC inline 6, and if a 52, or 53 model,with push button door handles, it will have a 302ci. GMC inline 6 cylinder engine. If a 450, or 470 series, it will have a Clark 5 spd., tranny, and a Eaton, electric shift 2 spd., rear axle. Nice truck. Check for a tag, on the back of the glove box lid. If there's one present, it will tell all about the trucks spec.s A 400 series, is a 2 1/2 ton, 450 series, is a 3 ton, and 470 series, is a 3 1 /2 ton. hope it's a case of mistaken identity. be a shame, if someone put a 292 Chevy engine, in that truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314536 Sun Jun 16 2019 07:42 PM
EdPruss Offline
Engine SN, r. side, behind distr. will start with displacement, I.e. 270xxxx, if GMC engine.
Ed
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314686 Tue Jun 18 2019 12:22 AM
I will be at the truck again this coming fourth of july weekend.
Will get better pictures then.
Thanks to everyone for all the great advice.
Re: 1952 GMC Dump..... [Re: Brian_Ostner] #1314991 Thu Jun 20 2019 11:46 AM
OldCarKook Offline
There are two ID plates to check; one on the driver's door hingepost and one on the inside back of the glovebox door. Both contain important information on the model and driveline configuration. The 4 speed suggests to me this is likely a 400 series with SM-420. Hard to guess which is why you need the information off the ID plates.
Page 1 of 2 1 2
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
