The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (archburycontrol, Flatblu4748, Christian, DennisM, Est2rad customs, 2 invisible), 254 guests, and 3 robots.
Forums50
Topics120,034
Posts961,357
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Rochester carb not squirting
#1314009 Tue Jun 11 2019 10:25 PM
So this is my first post. I've had my1950 3100 with a 6v 216 for 3 years.
In that time I've done plenty of work on it but it's been running and driving the whole time.
So 2 months ago it stalled on me after driving for about 30 minutes. Had never done that before. It was flooded. I ran the battery dead trying to get it started. The next day, on a full battery, it started right up and ran fine for a short drive around the neighborhood. Got home and parked it. Hasn't ran since.
Figured it was still flooding so since I was gonna open up the carb to check the float I figured I'd rebuild it.
I ordered a rebuild kit from mikes carbs, followed every online video I can find.
I found the check ball and spring next to power piston jammed into the power plug ( had the wrong size ball in there) also the air-fuel mix screw was chewed up like someone really cranked down on it. Ordered and replaced those parts and have fiddled with this thing for weeks but can't get a jet of fuel into the manifold.
The acc pump is doing its thing and pumping fuel past the check ball under the "T" but when I put it al together I get nothing.
Any help is greatly appreciated.
Re: Rochester carb not squirting
treydrummer #1314020 Wed Jun 12 2019 12:11 AM
Boltergeist
Check to be sure you've got the right gaskets- - - -it sounds like you've got a gasket blocking an accelerator pump passageway.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
treydrummer #1314062 Wed Jun 12 2019 08:54 AM
Will do. Thanks
treydrummer #1314063 Wed Jun 12 2019 10:39 AM
My Rochester that I have been using for years on my truck, is missing the nozzle for the spray in the throat. It works just fine but you can't see a mist or spray when moving the accelerator.
1951 1 Ton Completed
treydrummer #1314104 Wed Jun 12 2019 05:50 PM
In my limited experience after rebuilding our carb for similar reasons, it's either the check balls are not correct or missing, the plunger is not sealing or stuck (are the plunger springs correct?), or possibly the top hat of the carb is warped too much and not sealing.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Lindsey #1314106 Wed Jun 12 2019 06:00 PM
I put the larger steel check ball under the "T" on the Acc Pump discharge, the smaller with the power piston behind the power plug and spring. The acc pump seems to be doing its thing but i can't speak to whether the carb body is warped. That's on the list to check.
treydrummer #1314183 Thu Jun 13 2019 10:55 AM
So i found my problem with my carb. The jet off of the acc pump discharge was blocked. Someone had installed the "T" that holds the check ball and spring in a fashion that blocked the jet. I had to run a small 1/16 drill bit in to remove some the material and then used a tip cleaner for a cutting torch to push through the jet hole and open it back up. She pumps fuel like intended now.
Of all the videos and step by steps I've watched, i haven't seen anyone note that jet. The cut away diagram is what finally turned me onto the problem.
Thanks for all your guys' advice.
treydrummer #1314564 Mon Jun 17 2019 01:08 AM
Moderated
Thank you Treydrummer. I rebuilt a Rochester yesterday that had been sitting for a few years. I cleaned it well twice and still couldn't get it to pump. After seeing your post I opened it back up again and sure enough, the tee was turned the wrong way and had a little metal blocking the passage. I opened it up and viola it started pumping. Got to hear it run for the first time this evening.
treydrummer #1314618 Mon Jun 17 2019 02:23 PM
Happy to hear the thread was able to help you out.
treydrummer #1317554 Sat Jul 13 2019 02:07 AM
I have been struggling to figure out for months what's going on with my truck and after reading your OP, it was my problem down to a tee! I followed your instructions exactly as noted and just got back from a 30 mile drive, trouble free! I cannot even begin to thank you enough for sharing your trouble and solution, it's finally allowed me to enjoy my truck again with confidence!
Page 1 of 2 1 2
Moderated by  Woogeroo
