The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (55 SHAKER, dands, 3B, DennisM, 3 invisible), 282 guests, and 3 robots.
Forums50
Topics120,033
Posts961,331
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Any Holmes 440 Wrecker Owners Out There?
#1313984 Tue Jun 11 2019 02:55 PM
I've got a question or two about a Holmes 440 Wrecker. My Holmes is a '69 Model.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Re: Any Holmes 440 Wrecker Owners Out There?
C10 - C90 Bill #1313990 Tue Jun 11 2019 04:08 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Hey Spanky, you’ve got a call! 😁
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
C10 - C90 Bill #1313997 Tue Jun 11 2019 06:46 PM
Never owned a 440, but I can try to answer his question, or send him to the right person, or persons.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
C10 - C90 Bill #1314000 Tue Jun 11 2019 07:29 PM
Spanky,
I'm also talking about this problem on another site and have since learned some info, but I am having trouble with the Spring Loaded Pull Pins on the Bottom Bars. They keep interfering with my hook-ups. My Pins are facing Upward. Not sure how they came from the factory, but I've noticed today online that some 440's have them facing Downward. To me this goes against common sense and could be a safety hazard, but I'm just using the truck off road anyway. Twice last week the Pins got tangled up in the Bumper. Actually bent one of the Pins, but got it straightened out. Decided to just change them around, but just noticed that someone welded the Nuts !! This will make it a project for another time.
My other question was their purpose. I figured that the were there to extend the Bars out towards the Slings more, but there are no adjustment holes. Just the one. But just got explained to me that they were an aid on the hook-up process. Of all the times I rode with friends, they either never had it or never used it.
Holmes sure made great Wreckers, but wish they located these Pull Pins a little higher up on the Bars.
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill #1314003 Tue Jun 11 2019 09:16 PM
TGP Offline
I'm assuming your referring to the towing sling arms?
All the pins I have seen were pointed down.
There is only one set of holes as you noticed.
You pull the pin and slide the sling out to attach it to the vehicle.
Once you start raising the sling comes back to it original position
And the pins lock in.
The idea was to aid in hooking so you wouldn't have to be so critical of
You distance between the hook up, and also aid in not being square to the towed vehicle.
Tom
C10 - C90 Bill #1314040 Wed Jun 12 2019 02:58 AM
Not sure on the light duty wreckers, but on medium duty, and heavy duty units, each sling arm had 4, or 5 holes. While making your hookup, you would pull the pins outward, and turn them to hold out. You would then back up against bumper of the vehicle to be towed, hook up your chains, and secure, then while winch is lifting vehicle up, pins latch themselves into first holes available, as sling arms slide in. hope this makes sense. I could show you better than I could explain it.
Spanky Hardy
1950 GMC 250 1-Ton
C10 - C90 Bill #1314047 Wed Jun 12 2019 03:49 AM
Appreciate the replies. Yes, that's what I have been finding out. Both replies are good explanations of it.
Mine Pins are upward as mentioned and a look at about a dozen 440's online today showed about 1/3 of then upward and about 2/3's down. I haven't proved it yet, but it seems like the factory sent them out upwards. But the dang things are too many times in the way, lol.
When time allows, I'll be switching them around.
Thanks again.
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill #1314058 Wed Jun 12 2019 05:00 AM
J M Online
Every truck with a sling that I have used including my present truck had the pins pointing down. It seems to me that the pins would get caught on the bumper if they were up. I have never had a problem with the pins being in the way when they point down.
For what it is worth.
Jim
J M #1314082 Wed Jun 12 2019 12:46 PM
Jim
That's the problem I'm having Jim, interfering with the Bumper. Strange though as I believe they were upward from the factory and guys end up flipping them over, like I need to do.
Appreciate all the replies.
GMC 9500 Fan
Detroit Diesel Fan
Moderated by  69Cuda, Grigg
