The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (chaz71), 160 guests, and 3 robots.
Forums50
Topics121,069
Posts970,532
Members43,832
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Gear ratio change
#1313003 Mon Jun 03 2019 02:54 PM
I know Patrick's use to be the go to guy for a conversion kit to upgrade the gears in my stock rear end to get better highway speeds but with the issues Patrick had in the last year or 2 and the final demise of his business does anyone have a recommendation for a another vendor for these conversion kits?
I have a stock 54 3100.
Dave from Northern Kentucky
My 54 3100
Re: Gear ratio change
dgrinnan #1313004 Mon Jun 03 2019 03:15 PM
Contact Mothertrucker here on stovebolt.com via PM. He can fix you up.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
dgrinnan #1313009 Mon Jun 03 2019 03:55 PM
thanks
My 54 3100
dgrinnan #1313109 Tue Jun 04 2019 03:54 AM
The 3.55 gears will only bolt in to the 1940-1953 trucks.
In order for them to work in a 1954 rear end you will need to locate a 47-53 ring gear carrier assembly & install it along with the new gears.
dgrinnan #1313139 Tue Jun 04 2019 01:53 PM
Okay, that changes things significantly. Not plug and play. How would you rate this task.
Something a weekend mechanic can take on in his driveway?
Any special tools required?
My 54 3100
dgrinnan #1313151 Tue Jun 04 2019 03:32 PM
ace skiver
Have you seen/found/read the two Stovebolt.com Tech Tips?
Also: do not be scared-off the need for the 47-53 carrier replacement in a 1954/55st job.
Finding the 4.11 carrier is far more difficult than replacing the carrier (post a Part Wanted ad here).
The change is not exactly "plug and play".
And, you will need to buy/borrow some tools (as shown in the Tech Tips).
We cleaned all parts/housings and did the first conversion in two 4hr sessions.
The second time we did it in about 4 hours (including cleaning all parts - which took a couple hours).
I had help from a friend who is a mechanic, but he had never been inside a Stovebolt enclosed driveline.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1313311 Wed Jun 05 2019 08:02 PM
I have found it extremely difficult to locate that gear carrier assy cause I am in the same situation
posey #1313437 Thu Jun 06 2019 06:58 PM
Maybe keep an eye on T-5 swap or 5-lug swap discussions where guys are no longer using the enclosed driveline parts..?
dgrinnan #1313699 Sun Jun 09 2019 02:08 AM
Going from 4.11's to 3.55 was one of the best mods I did to the green turd.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
posey #1313710 Sun Jun 09 2019 04:11 AM
I have one laying around, I could part with.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Moderated by  SWEET
