The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 registered members (sack, Tommy, John Dlugos, 1 invisible), 423 guests, and 4 spiders.
Forums48
Topics117,297
Posts937,857
Members42,893
Most Online1,229
Jan 21st, 2020
Image Posting Policy
disc brakes on a '49 #1311571 Thu May 23 2019 01:40 AM
52Carl Offline OP
I want to put disc brakes on my '49. I currently have Huck brakes on the front, and 1970 Bendix on the back.
So I am assuming that I will need a dual master cylinder. I want the one which goes under the floor in the original spot.
I have a Th400 transmission behind a 350 engine. Will the vacuum assist version fit next to the automatic transmission?
How about proportioning valve?
How about interference between the axle and the caliper on hard turns?
Re: disc brakes on a '49 [Re: 52Carl] #1311578 Thu May 23 2019 02:06 AM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
My sonโ€™s โ€˜53 has under the floor power brakes w/dual master cylinder. The truck is a 350/700r4. He is running a proportioning valve. Camero subframe so the rubbing is not an issue. ๐Ÿ›
โ€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iโ€™m #2)
โ€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: disc brakes on a '49 [Re: 52Carl] #1311611 Thu May 23 2019 12:21 PM
showkey Offline
Dual master.........yes
Proportioning valve .........yes
Axle interference on tight turn ...................Huge discussion point, reality is makes little or no difference when driving.
Automatic trans clearance ................not sure. My 1950 GMC 6 cylinder 4 speed manual is close and needs a right angle speedo drive to clear.
Re: disc brakes on a '49 [Re: 52Carl] #1311819 Fri May 24 2019 05:43 PM
just-a-hacker Offline
I did need to put a different master cylinder on mine,mounted in original position.
I did not need any vacuum .
The kit I used was pretty easy to install .
Mine is also a 49
I used http://www.ecihotrodbrakes.com/ mainly because I could visit their shop and see operation, then I was able to pick up there
just-a-hacker
'49 3100 before '99
Re: disc brakes on a '49 [Re: 52Carl] #1311835 Fri May 24 2019 07:23 PM
Lindsey Offline
While looking into brakes for our '53, I was told master cylinders put out different pressures depending on brake type, drum vs. disc.
The issue with vacuum assist is apparently clearance with the manual transmission side linkage typically, which is why most say they only work WITH an automatic transmission, or likely with a floor shift manual.
Not sure about axle/caliper clearance. I decided to stick with drums all around for now but ordered a dual master cylinder for a little extra safety.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
