The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (FinnBolt, Bill Marlow, DennisM, cmayna, 5 Window 9434, 2 invisible), 109 guests, and 4 robots.
Forums47
Topics117,794
Posts942,573
Members43,043
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1951 Panel 1 ton brake drum diameter??
#1311523 Wed May 22 2019 07:17 PM
I have more zippers then a pair of cargo pants
Does anyone know what specs (the max they can be turned) for the brake drums for a 1951 Chevy 1 Ton Panel? ... thanks...joe
Donate Blood, Plasma, Platelets & Sign Your DONORS CARD.
The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist:
Either we are alone in the Universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Re: 1951 Panel 1 ton brake drum diameter??
TooMany2count #1311759 Fri May 24 2019 04:42 AM
3B Offline
Hy TooMany2count. without actually looking up the specifications I would say .060", hope that helps.
3B #1311761 Fri May 24 2019 05:24 AM
Thanks, but I need the total inside diameter so I when I use a brake drum gauge,I know if the drums are good or not....joe
Arthur C. Clarke
TooMany2count #1311797 Fri May 24 2019 03:20 PM
3B Offline
Hy again TooMany2count, according to my truck salesman's data book your truck should have 12" front brakes and 14" rear brakes, the maximum diameter on your gauge for the front brakes would be 12.060 and the maximum diameter on your gauge for the rear brakes should be 14.060. The rear brakes may be able to be turned out to 14.090 but I will keep looking for the specification to be sure, hope that helps.
3B #1311804 Fri May 24 2019 04:28 PM
Thanks & yes that helps a lot, it'll give me some idea if they are worth saving or if they become scrap....joe
Arthur C. Clarke
TooMany2count #1312411 Thu May 30 2019 01:39 AM
I have found very little mention of this limit in the shop manuals. The Chev manual mentions turning the drum out to 60 and installing the stock oversize shoes. There is mention in one of the GMC manuals of .125" as the limit. I would guess that most shops would automatically say .060". By the way you can't buy these drums new and they are very hard to find used or NOS .
1951 1 Ton Completed
TooMany2count #1312412 Thu May 30 2019 01:51 AM
ace skiver
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
tclederman #1312447 Thu May 30 2019 06:43 AM
Tim thanks for the info & the link....joe
Arthur C. Clarke
TooMany2count #1312576 Fri May 31 2019 02:29 AM
Joe, Eli and I are working on his truck. Should have a spare set of rears coming up this summer. No idea if they are turnable or not but can check my friendly neighborhood mechanic once we get them off.
Just here for the free beer.
1953 1-Ton Dump Truck
1954 Teenage Hot Rod
Moderated by  tclederman
