The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 registered members (), 236 guests, and 3 spiders.
Forums47
Topics116,079
Posts922,946
Members42,329
Most Online940
Apr 5th, 2017
Image Posting Policy
Front end opinions: damaged goods or salvageable? #1311595 Thu May 23 2019 04:42 AM
Fox Offline OP
I tore the front end out of the AD 1/2 ton frame tonight. Things are better than I expected. However, I want opinions on these springs and the axle. Should I refurbish the springs or replace them? I could disassemble them, lightly grind out the wear, radius, etc and reinstall with new bushing, etc. It would be nice to save the near $500.
Also, is this straight axle bent? It sure looks like it to me.
What do the Bolters think?
https://photos.app.goo.gl/3BmYStHNvJGR4Y7i8
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311612 Thu May 23 2019 12:31 PM
Grigg Offline
Axle surly has a forward bow in it. May be possible to press it back straight or may be easier to find another.
Depending on how worn the king pin bores are in the spindles you may be (likely) looking for better spindles anyhow, and they often come on a good axle beam.
Springs are worn, I don’t know about grinding them if that’s advisable or not.
1952 Chevrolet 3800 pickup
---All pictures---
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311613 Thu May 23 2019 12:33 PM
SavannahDog Offline
Why take the springs apart? Just clean/grind them as a whole. And axle straightening is practiced, You just need a rather large press to do it with. I haven't done either.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311620 Thu May 23 2019 01:11 PM
Joe H Offline
My original springs were wore more then yours, I pulled them apart and radiuses each worn step and the matting spring that dug the step. I then added some leaf spring liner material to help them slide on each other. Springs are very hard, it took some work to radius the grooves and to clean the rust off. As a side note, I greased each wear point before installing the next leaf, a year later (1100 miles ) I had them back out due to squeaks. The grease was gone from where I put it with rust in its place, that when I went to the liner material.
I drove with them this way for many years without any problem. In the last couple years I changed all four out for a softer ride, sold the OEM springs to a rat rodder and suspect they are still on the road.
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311623 Thu May 23 2019 01:20 PM
Hotrod Lincoln Offline
Boltergeist
With as many people out there who insist on replacing a good front axle with some sort of Mickey Mouse independent suspension system, there should be a truckload of axles free for the taking. Put an ad in the "parts Wanted" forum and I'll bet you can find one in better condition to use as a starting point for a rebuild.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311703 Thu May 23 2019 10:21 PM
Lindsey Offline
I was poking around kijiji today and saw an identical setup, but for a '57, for $200 CAD in the Calgary area. So they are definitely out there for a decent price...
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Re: Front end opinions: damaged goods or salvageable? [Re: Fox] #1311714 Fri May 24 2019 12:23 AM
Fox Offline OP
Thanks guys. I actually have a parts truck that I think has a good axle. I should be able to make one setup out of these two. I think I’ll clean up he springs, swap axles and put in new kingpins, etc. The frame is 53 and the parts truck is a 51 so I should be good to go.
More pictures here
Parts trucks-
1951 GMC 9300
1951-GMC 9430
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.7.3
