The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (89sbr), 270 guests, and 2 spiders.
Forums47
Topics115,013
Posts912,553
Members42,079
Most Online940
Apr 5th, 2017
Image Posting Policy
Help ID my transmission #1311437
Tue May 21 2019 09:01 PM
bztguy  Offline OP
Oregon, IL
I could use some help ID'ing the the transmission in my 70 GMC half ton. I need to get a seal kit for it. It's a stock 3 speed manual mated to the original 307. The casting numbers are a little hard to read on the LH side but appear to be like 3862845. The RH side 8825647.
Thanks for the help.
1949 Chevy 3600
1975 W-25 Hurst Olds
1991 Chevy Silverado
1970 GMC 1/2 ton Fleetside
I'm a GM man!
Re: Help ID my transmission [Re: bztguy] #1311439
Tue May 21 2019 09:15 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
It's probably a Saginaw. How many bolts are there holding the side cover onto the case? Saginaw 3 speeds have 7 bolts, and Muncie SM 318's have 4 bolts. By 1970, I'm pretty sure all the 3 speeds were Saginaw.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Help ID my transmission [Re: bztguy] #1311581
Thu May 23 2019 02:09 AM
EdPruss  Offline
Longmont, CO
One can always carefully remove the seals and get the PN off them.
Ed
Re: Help ID my transmission [Re: EdPruss] #1311583
Thu May 23 2019 02:25 AM
bztguy  Offline OP
Oregon, IL
Well it has 7 bolts making it a Saginaw. I see Rock Auto has seal/gasket/bearing kits for it for about 90 bucks. My own stupid fault. I'm restoring the truck and had it disassembled down to nothing but the cab on the frame. The trans was working fine so I left it as is other than a new clutch, flywheel, and throw out bearing. I didn't stop to think about the fact the truck had been sitting for years. After about 50 miles of shakedown driving the old dried front seal is now leaking......now that the truck is 95% complete......argh....
1949 Chevy 3600
I'm a GM man!
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
