The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (D B Cooper, 1953 panel, WE b OLD, Barnfind49), 229 guests, and 3 robots.
Forums50
Topics120,013
Posts961,184
Members43,538
Most Online1,229
Jan 21st, 2020
Image Posting Policy
disc brakes on a '49
#1311571 Thu May 23 2019 01:40 AM
52Carl Offline OP
I want to put disc brakes on my '49. I currently have Huck brakes on the front, and 1970 Bendix on the back.
So I am assuming that I will need a dual master cylinder. I want the one which goes under the floor in the original spot.
I have a Th400 transmission behind a 350 engine. Will the vacuum assist version fit next to the automatic transmission?
How about proportioning valve?
How about interference between the axle and the caliper on hard turns?
Re: disc brakes on a '49
52Carl #1311578 Thu May 23 2019 02:06 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
My sonโ€™s โ€˜53 has under the floor power brakes w/dual master cylinder. The truck is a 350/700r4. He is running a proportioning valve. Camero subframe so the rubbing is not an issue. ๐Ÿ›
โ€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iโ€™m #2)
โ€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
52Carl #1311611 Thu May 23 2019 12:21 PM
Dual master.........yes
Proportioning valve .........yes
Axle interference on tight turn ...................Huge discussion point, reality is makes little or no difference when driving.
Automatic trans clearance ................not sure. My 1950 GMC 6 cylinder 4 speed manual is close and needs a right angle speedo drive to clear.
52Carl #1311819 Fri May 24 2019 05:43 PM
I did need to put a different master cylinder on mine,mounted in original position.
I did not need any vacuum .
The kit I used was pretty easy to install .
Mine is also a 49
I used http://www.ecihotrodbrakes.com/ mainly because I could visit their shop and see operation, then I was able to pick up there
just-a-hacker
'49 3100 before '99
52Carl #1311835 Fri May 24 2019 07:23 PM
While looking into brakes for our '53, I was told master cylinders put out different pressures depending on brake type, drum vs. disc.
The issue with vacuum assist is apparently clearance with the manual transmission side linkage typically, which is why most say they only work WITH an automatic transmission, or likely with a floor shift manual.
Not sure about axle/caliper clearance. I decided to stick with drums all around for now but ordered a dual master cylinder for a little extra safety.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Moderated by  SWEET
