The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (5WINDOWJOHN, coilover, Geo55, KEVINSKI, 49shep, Justhorsenround), 268 guests, and 3 robots.
Forums50
Topics119,993
Posts961,025
Members43,528
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Cruising down the road
#1311559 Thu May 23 2019 12:20 AM
Elmo Offline OP
Driving down the road in my 53 3600 Chevy truck! Recently put a Tach in the truck! Tonight I was driving to take the truck to get the pinion seal replaced. At 50 miles an hour, the truck was pushing 2500 RPM’s. So can this truck sustain 50 miles an hour for long period of time? Or is that pushing my luck?
Re: Cruising down the road
Elmo #1311565 Thu May 23 2019 12:46 AM
2500 at 50 mph is very possible. What are your gear ratio in back?
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Elmo #1311567 Thu May 23 2019 01:01 AM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Elmo #1311568 Thu May 23 2019 01:09 AM
I don't get scared until 3,000 RPM.
2,500 RPM is right in the wheel house of the optimal power range for these inline six engines.
Elmo #1311575 Thu May 23 2019 01:52 AM
Elmo Offline OP
Oh and by the way my truck has a 235 in it. Not a 216.
Elmo #1311599 Thu May 23 2019 06:28 AM
So you weren't worried until you installed a tach? That's kinda like having a thermometer; you're not cold until you look at it - then Brrrrrr!
1951 Chevy Panel Truck
Elmo #1311604 Thu May 23 2019 11:16 AM
Vintage Truck & Tractor
I remember when they all used to be spooled up that high to go down the highway. Seems gasoline engine rpm has decreased a lot since the late eighties. If the engine is in good condition it should be ok.
Current project; 1961 C20, 235 I6
Elmo #1311629 Thu May 23 2019 01:41 PM
There has been some discussion on this topic recently, and I too myself have been interested in learning what the "reasonable" engine speeds are for these trucks. I run my 261 (and previously a 216) at 50-55 and don't think twice. The engine does sound like it's winding up pretty good, but I know they are designed to handle these speeds given proper lubrication and cooling. My thought on this subject is these trucks were not designed for freeway speed, and I become much more concerned with safety than engine speed when speeds exceed 55mph in stock form.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Elmo #1311639 Thu May 23 2019 02:14 PM
ace skiver
1953 31xx truck with 4.11 rear end?
What is the rolling diameter of your tires?
1953 transmission (there was a 1:1 top gear in the original 3-speed or 4 speed)
With those data, we/you can calculate engine RPM at different speeds.
Then, we can offer opinions (and BS) on what we consider to be a safe engine speed.
Tim
Elmo #1311641 Thu May 23 2019 02:24 PM
Elmo Offline OP
3600
4.57 rear end gears
16 inch tires
4 speed on the floor
Page 1 of 3 1 2 3
Moderated by  Justhorsenround
