The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 members (55 SHAKER, jmmmn37, Johnny N, 20Mercman, fonz8261, 1 invisible), 232 guests, and 4 robots.
Forums58
Topics121,883
Posts982,797
Members44,337
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
235 Rocheser Carb Base to 216 Carb Swap
#1311556 Wed May 22 2019 11:50 PM
I was wondering if I could swap the base from a 235 rochester carb to a 216 carb. Anyone know if it will work? My 235 Rochester carb is bad and I have two good Rochesters from 216 engines. If I can just swap the bases to match the 235 bolt pattern then I'd be good to go.
Still trying to get ole Betsy back on the road.
Re: 235 Rocheser Carb Base to 216 Carb Swap
Craig /49 Panel #1311569 Thu May 23 2019 01:10 AM
Carburetion specialist
Will it work?
Maybe.
Will it work well? Should be good for a 20 percent power LOSS.
Jon.
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
Craig /49 Panel #1311619 Thu May 23 2019 01:08 PM
I agree, can't run properly.
Craig /49 Panel #1311628 Thu May 23 2019 01:39 PM
X3
I did this with a Carter and it ran. However, once I finally located the correct Carter YF for my 235 the performance and gas mileage were noticeably improved.
If I were you, I'd keep looking for a 235 carburetor. Place an ad in the Swap Meet 'Truck Parts Wanted' forum.
Andy
His: 1947 Chevrolet 3104 [flic.kr]
Hers: 2008 American Saddlebred [flic.kr]
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Craig /49 Panel #1311669 Thu May 23 2019 05:48 PM
I have seen the carbs for the 216 with the mounting holes elongated to mount them. Folks do what they need to do to keep them on the road!
1951 1 Ton Completed
Craig /49 Panel #1311790 Fri May 24 2019 02:22 PM
Okay, thanks everyone - that answers my question. Now how do I find out what is the correct Carter carb for my engine?
Craig /49 Panel #1311891 Sat May 25 2019 11:23 AM
Craig /49 Panel #1311914 Sat May 25 2019 03:53 PM
Thanks. Looks like I need 2100s for my 54 235.
Craig /49 Panel #1312353 Wed May 29 2019 07:43 PM
Hey Jon, I found a 788 YF will that work ok. Your list says 1959-52. Mine is a 1954.
Craig /49 Panel #1312420 Thu May 30 2019 02:14 AM
788s fit 1950~1952, not 1959-1952.
Will it work?
Don't know. Have always thought engineers knew what they were doing.
Check the second line in my signature block.
Jon.
Page 1 of 2 1 2
Moderated by  Woogeroo
