The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (agedhorse, klhansen, tomctomc), 285 guests, and 3 spiders.
Forums47
Topics115,013
Posts912,553
Members42,079
Most Online940
Apr 5th, 2017
Image Posting Policy
41-46 fuel line size/ material? #1310996
Fri May 17 2019 01:25 PM
Bill39568  Offline OP
NY
What is the correct fuel line size and material from tank to pump and pump to carb? My truck has 1/4” od steel to the pump and 3/8” od from pump to carb. Also I have plain brass male x compression fittings. Are these correct?
44 Canadian chevy 1/2 ton
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311008
Fri May 17 2019 03:05 PM
cmayna  Offline
Menlo Park, Ca
Not 100% sure on size but will say, I'd go with copper/nickel material once the size is determined.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: 41-46 fuel line size/ material? [Re: cmayna] #1311529
Wed May 22 2019 08:16 PM
NY
Looks like a good way to go.
Anyone on diameter of tubing?
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311533
Wed May 22 2019 09:07 PM
Harold46  Offline
Georgia
I used the following lines from NAPA. Also available at Advance and Auto Zone.
Fuel Line From Pump to Carb 5/16" X 40"
Fuel Line Pump To Tank 5/16" X 60"
Harold
Harold
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311562
Thu May 23 2019 12:37 AM
NY
Thank you both!
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
