The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 registered members (matthews940, greenie-reddy, 78buckshot, Harold41, 5 Window 9434, 1 invisible), 328 guests, and 4 spiders.
Forums47
Topics116,116
Posts923,327
Members42,345
Most Online940
Apr 5th, 2017
Image Posting Policy
41-46 fuel line size/ material? #1310996 Fri May 17 2019 01:25 PM
Bill39568 Offline OP
What is the correct fuel line size and material from tank to pump and pump to carb? My truck has 1/4” od steel to the pump and 3/8” od from pump to carb. Also I have plain brass male x compression fittings. Are these correct?
44 Canadian chevy 1/2 ton
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311008 Fri May 17 2019 03:05 PM
cmayna Offline
Not 100% sure on size but will say, I'd go with copper/nickel material once the size is determined.
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: 41-46 fuel line size/ material? [Re: cmayna] #1311529 Wed May 22 2019 08:16 PM
Looks like a good way to go.
Anyone on diameter of tubing?
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311533 Wed May 22 2019 09:07 PM
Harold46 Offline
I used the following lines from NAPA. Also available at Advance and Auto Zone.
Fuel Line From Pump to Carb 5/16" X 40"
Fuel Line Pump To Tank 5/16" X 60"
Harold
Harold
Re: 41-46 fuel line size/ material? [Re: Bill39568] #1311562 Thu May 23 2019 12:37 AM
Thank you both!
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
