The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 registered members (49chevyfivewindo, 55 SHAKER, hapydirty, 59 Apache Dlx, 3 invisible), 283 guests, and 1 spider.
Forums47
Topics115,207
Posts915,175
Members42,197
Most Online940
Apr 5th, 2017
Image Posting Policy
Door weatherstrip question #1311474 Wed May 22 2019 03:02 AM
Jon G Offline OP
Hi folks. The door weatherstripping...that is to say the seal that is glued to the doors...who has bought what lately and what is the consensus on what is best? I need to replace mine during a repaint. I have some made by GM, but it is apx 40 years old. Looks ok but I'm hesitant to use it because of the age. Ideas? Suggestions?
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Re: Door weatherstrip question [Re: Jon G] #1311519 Wed May 22 2019 06:16 PM
MNSmith Offline
For your '52?
Re: Door weatherstrip question [Re: Jon G] #1311545 Wed May 22 2019 11:03 PM
Jon G Offline OP
Yes Mark, for the 1952 1/2 ton. I'm repainting it and want to go with new weatherstripping...at least the door to body stripping. What I recall from comments over the past 5 years is that some is too firm leading you to need to slam the doors. That's what I'm trying to avoid.
Jon
Re: Door weatherstrip question [Re: Jon G] #1311549 Wed May 22 2019 11:16 PM
Justhorsenround Offline
Grease Monkey
Jon, I think it’s just a shot in the dark with the thick/thin issue. Personally I would rather have it too thick. Install in the heat of the summer and leave the door shut, out in the sun, for a couple of days. Should help the seal conform to the gap quite nicely. JMO
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Door weatherstrip question [Re: Jon G] #1311558 Thu May 23 2019 12:11 AM
MNSmith Offline
I've had good luck with whatever Classic Parts has been selling lately.
Re: Door weatherstrip question [Re: Jon G] #1312082 Mon May 27 2019 02:13 PM
Jon G Offline OP
Thanks Mark, Martin. If you install in Dallas the heat will certainly change most foam.
Jon
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.2
