The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (gsharum, Jerry M., 51 3804, David Sr, NJC, 1 invisible), 233 guests, and 2 robots.
Forums50
Topics122,162
Posts979,935
Members44,165
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1951 4400 engine horse power
#1311544 Wed May 22 2019 11:01 PM
I have a 1951 4400, relatively all original if you don't count an old paint job. All the serial numbers date to 1951, so it's intact. My question is; why is my truck only rated at 85hp, and why is it a 216. Everything I can find lists my truck as a 235, and all 216's should have 92hp. I've read that Canadian trucks never got the 235 and they had lesser horsepower, my gauges are in miles per hour I do know that Canada switched to metric in 1971. I'm thinking I might have a Canadian truck, I did buy it in northern Minnesota. Thoughts? Thanks, B. Kelley
Re: 1951 4400 engine horse power
B.Kelley #1311547 Wed May 22 2019 11:11 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Your truck falls into the Big Bolt category. We have several members that are familiar with the Canadian trucks and the engines associated with them. Someone will be along shortly.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
B.Kelley #1311553 Wed May 22 2019 11:28 PM
ace skiver
USA 1951 4400 trucks came standard with a 216.
1954 (USA) Chevrolet Specifications (truck engines)
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #1311554 Wed May 22 2019 11:39 PM
Thanks. That makes sense now, the tag lists net horsepower not gross. As for the 216 being standard, you're the first one to state that and show proof. I have been wondering about that for the longest time, you've scratched my itch.
B.Kelley #1311607 Thu May 23 2019 11:52 AM
On some years the trucks had a restricter on the intake, presumably to limit how hard they were driven. If you look at some of the horsepower curves you will see that the truck curves peak before the ones on the car engines. I have always thought that this was due to the heavier pistons in the truck engine.
1951 1 Ton Completed
Moderated by  69Cuda, Grigg
