The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (frankiefifty, BC59, 51sub, bandbrent, Curt B., 55_2nd_Series), 328 guests, and 3 spiders.
Forums47
Topics116,101
Posts923,144
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: Tyler Watts] #1311244 Mon May 20 2019 12:40 PM
Hotrod Lincoln Online
Boltergeist
That's a passenger car bellhousing for a 216. Apparently someone had the 235 in an earlier chassis before you got it.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: Tyler Watts] #1311249 Mon May 20 2019 01:23 PM
MikeE Offline
I seem to remember playing this game when I put an SM 420 into my 46 Panel truck. One of your bell housings is probably for the original non synchro 4 speed. When you switch everything around to get the SM 420 to match the bell housing, you may need to check that the starter and flywheel work together and that the clutch and brake pedal assembly still bolt up to the right places. This may not be an issue for you, but I had to fight that battle with a modified bell housing. Think it was something between 46 and 47 body styles.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: MikeE] #1311357 Tue May 21 2019 03:38 AM
Tyler Watts Offline OP
Mike,
I got everything back together. I just put my original 216 bellhousing on the 235. I do happen to have an older 4 speed (pre-SM420, don't recall the model # off the top of my head) laying around, so I'll check for curiosity's sake to see if it matches up to that bellhousing.
1953 Chevrolet 3/4-Ton 3600 Pickup
1946 Fleetline Aerosedan
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: Tyler Watts] #1311390 Tue May 21 2019 02:12 PM
MikeE Offline
The older 4 speed, the one with the lever for reverse, doesn't match up with the SM 420 bolt pattern. But the old bell housing will will bolt to a 235. So the front is compatible but the back isn't. I am not sure if there was another 4-speed between the reverse lock out model and an SM 420, I don't think so but I am not too familiar with the transmission development process.
1946 1-ton Panel
My Webshots Album
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: MikeE] #1311470 Wed May 22 2019 02:34 AM
Mike,
Right you are--I held up my earlier 40's 4-speed (the one with the lock-out reverse as you noted) and yep, it's a match for the bellhousing I initially had on the 235. The p.o. of this engine must have had it in an earlier truck with that 4 speed. From what I've read, that trans went up to '47, and then the SM 420 came out in '48, if I remember correctly.
Re: Engine swap success/ fail (235 replacing 216 in '53 3600) [Re: Tyler Watts] #1311493 Wed May 22 2019 01:33 PM
MikeE Offline
It's fun to play musical parts!
1946 1-ton Panel
My Webshots Album
Page 2 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
